Sakharov
| Posted: Fri Sep 25, 2015 1:54 pm Post subject: BG808S image flikering mainly in lower corner HELP |
Dear firends and crt gurus,
I'm facing a problem with my BG808s. Once and a a while the lower corners of the image "flicker" like move and than stabilize, them after a while move again and so on.
Do you guys have any idea what could be the problem?
best regards
| Posted: Fri Sep 25, 2015 2:49 pm Post subject: |
Check the 17 volt test point on the power supply to see if it is off. Info is on the main site. Can't link to it from my phone, sorry !
Sakharov
| Posted: Wed Oct 07, 2015 1:26 pm Post subject: |
Thank you for the suggestion, but could you be more specific
Regards
Decibel
Joined: 31 May 2007 Posts: 904 Location: Roma - Italia
| Posted: Wed Oct 07, 2015 2:20 pm Post subject: |
Curt said this
_________________ Domenico (Barco fan!)
Sakharov
| Posted: Tue Dec 22, 2015 8:56 pm Post subject: |
Hi guys,
Finally i had the chance to measure it and it reads 17.44v. Should I ajust to 14v?
Regards
Merry Christmas
| Posted: Tue Dec 22, 2015 9:10 pm Post subject: |
No, to 17 volts. See if by turning the pot a bit the flickering stops. 17.44 usually doesn't show issues on the screen, it's usually if you're out by more than 1 1/2 to 2 volts.
Sakharov
| Posted: Tue Dec 22, 2015 9:17 pm Post subject: |
The strange is that the flikkering is not constante. Sometimes it happens not always. In one hour it happens once, more or less
