do you really need RTV for changing out C elements?
digitalayon
Posted: Mon Aug 03, 2015 7:38 pm    Post subject: do you really need RTV for changing out C elements?
I only ask because I saw Nash's video(think it was him) of a swap and he did not use any. What about using a O rings that came from other units? I will be doing this on my 9500 LC. Also I did not touch the C element when taking it out but my son did. I do not see any prints. However what's best way to clean and wipe to be sure? How do you guys do it when transitioning the lenses and transporting or shipping and preinstall prep?
jbmeyer13
Posted: Mon Aug 03, 2015 8:39 pm    Post subject: Re: do you really need RTV for changing out C elements?
You can get a optical cleaning kit from a camera shop which should have a very fine microfiber cloth and spray solution for cleaning the C element. Try to buy a second micro fiber cloth of the same grade so that you have one for cleaning and the other for drying. Use a lot of liquid to make sure there's adequate lubricity when cleaning as this will prevent scratches.
Nash was swapping a C-element onto a newer tube that didn't have the elements glued in place. I've had both tubes with and without so it all depends on what you have.
As for shipping; PM CIR Engineering as he ships bullet proof packaged red c-elements all the time.
digitalayon
Posted: Mon Aug 03, 2015 8:53 pm    Post subject: Re: do you really need RTV for changing out C elements?
Ah ok.....so If mine were not glued, don't use it? I still have the o rings from the 1292......any reason not to use that? Where is CIR getting the red C's? I tried to get one from him last year and he didn't have any.
jbmeyer13
Posted: Mon Aug 03, 2015 9:43 pm    Post subject:
He may not have any at the moment but he has a lot of experience (and is very thorough) when packing them.
If its not glued in then no need to glue it in place. You have to be careful when locating the O-ring (I would use the O-ring that came with the Marquee-I see no reason to use the one from the 1292) because if doesn't sit flush you'll get a leak.
digitalayon
Posted: Mon Aug 03, 2015 10:03 pm    Post subject:
I am wondering if the Marquee O-rings just get a little warped over time and the advanced article on this site using RTV is precautionary. However RTV IS A 24 HOUR SET. Wondering why it says 5 days or a week or whatever the hell it says.
Posted: Mon Aug 03, 2015 10:23 pm    Post subject:
I've never used RTV, and have swapped out many Marquee elements. HOWEVER.. if there are chips out of the plastic of the C element you are trying to put in, it will leak. Barco had the better idea with the O ring. I think the O ring in a MArquee will lift the C element too high though, causing potential leak issues in itself.
digitalayon
Posted: Mon Aug 03, 2015 11:43 pm    Post subject:
thx Curt.....little confusing considering the process info listed in the "Advanced Procedures". But I know those are not all you making them.
Posted: Mon Aug 03, 2015 11:47 pm    Post subject:
Never used silicon for that. Its probably counter productive as it might effect the O ring seal.
digitalayon
Posted: Tue Aug 04, 2015 3:02 am    Post subject:
well I got the info here
http://www.curtpalme.com/Changing_C_Elements7.shtm
Posted: Tue Aug 04, 2015 4:29 am    Post subject:
To my knowledge the O ring is designed to seal without silicon but i can see why you might be confused with differing information. When you removed the C element did the O ring have silicon on it.
digitalayon
Posted: Tue Aug 04, 2015 4:46 am    Post subject:
Not sure.....have yet to remove anything from the 9500lc......I pulled the red c from a Sony 1292 unit
Posted: Thu Aug 06, 2015 1:34 am    Post subject:
I don't think I have ever seen a colored C-Element siliconed in on a 9" Barco or a Sony before. I certainly wouldn't glue it in on either of those makes. On Marquee they come both ways, but I never silicone them unless like Curt says, there is damage on the contact surface already... usually the said damage comes from removing old silicone from an element that was in a Marquee.
I just retubed and swapped C-Elements on an MP9 two days ago; I took the old siliconed red out of the original MP9 and replaced the clear that was not glued into his new Marquee tube. I was forced to put a very thin layer of RTV on the element because I put some minor abrasions on the element removing the original silicone.
If you use RTV be sure to use the original silicone formula. This is usually called "silicone 1" now (by GE). Don't ever use "silicone 2" or "silicone II" as this does not cure the same way (I can elaborate if you want). You can easily get clear silicone 1 at HomeDepot, but black must be mail ordered (clear is fine on a C-Element).
When I remove C-Elements I take them to the sink and rinse them in water. I then use regular dish soap (nothing abrasive) and my bare hands to clean the C-Element under running water. I dry them primarily by patting dry with paper towels and then I go over them lightly with a dry microfiber cloth to pick up any lint.
If I have a C-Element container I store and ship in that. If not I tightly wrap the element in shrink wrap (or plastic wrap). I then put the element inside a plastic bowl with the same diameter as the contact surface so that the bowl holds the C-Element without anything touching or rubbing the element's surface. Next I cut a circular piece of cardboard to go over the bowl and shrink wrap that in place. After that, it's a large box with loads of Styrofoam peanuts. I can post a photo if this is not clear.
I've never had a C-Element get any damage with these methods. Before installation, I always clean the C-Element with a 50/50 mix of denatured alcohol and water using a spray bottle and microfiber with very little pressure on the cloth. I have never scratched a C-Element this way.
Best,
