Barco 1208/1209/1209s H line squiggle solved!
Posted: Thu Jul 09, 2015 2:18 pm    Post subject: Barco 1208/1209/1209s H line squiggle solved!
I'm not sure if this is public knowledge, but I finally figured out what causes a bunch of Barcos, specifically the 1208/1209/1209s to have a sine wave wiggle towards the left side of the screen. THe horizontal scanning lines have a slight sine wave to them, usually in the far left 10% of the screen. I spent a few hours swapping boards to no avail a few years back, and I gave up.
I was at a customer's place on Tuesday, and he had a horrendous squiggle, so I decided to set up a 1209s here again, and it also had the same issue, so I dove in.
I changed the V board, H shift/focus board and H output board (as I had years ago), and no change.
I then directed my attention to the yoke board, not thinking it was related in any way, but indeed it was.
Each one of those yoke boards has several large whitish 5 watt power resistors on it that stand up vertically on the board. There's no support for them, so they bounce around, and with most of these sets having been moved many times, I found that the resistors snap off at the bottom, where the resistor meets the PC board. While my test set was on, I wiggled each resistor, and found one that had a broken connection. Looking at the test grid, I touched the resistor base to the PC board trace, and that squiggle instantly cleaned up.
Whether you replace the resistor, or simply tack it back onto the board using the existing resistor is your call. Maybe a drop of hot glue will give it better support, but if your set is permanently installed, then tacking the resistor connection back together will probably last the life of the set.
Taking the board out is a bit of a PITA, so worst case, take it off its screw mounts, and that will give you a few inches of room to work with the board.
Ya learn something new every day..Smile
barclay66
Posted: Thu Jul 09, 2015 7:41 pm    Post subject:
Well done and thank You for sharing!
Regards,
barclay66
gregstv
Posted: Thu Jul 09, 2015 8:14 pm    Post subject:
Great work Curt,
Thanks for sharing your findings.
Decibel
Posted: Fri Jul 10, 2015 4:23 am    Post subject:
Great Curt
Thank you!
Domenico (Barco fan!)
Posted: Sat Jul 11, 2015 5:28 am    Post subject:
What is the cause of this on a Cine 9?
Posted: Sat Jul 11, 2015 2:32 pm    Post subject:
Not the yoke board!Smile
Posted: Sat Jul 11, 2015 11:59 pm    Post subject:
Yeah well that is obvious, but thanks all the same Wink Ill figure it out.
gregstv
Posted: Sun Jul 12, 2015 2:39 am    Post subject:
There is a guy on this forum that will tell you the best way is to pull it down and put up an NEC Very Happy
Decibel
Posted: Sun Jul 12, 2015 8:36 am    Post subject:
Mr. Green Mr. Green Mr. Green Mr. Green
Posted: Sun Jul 12, 2015 10:01 am    Post subject:
Yep, would be that same arrogant **** that has given many hours of his free time and helped out so many people on this same forum too. The same one you told a couple weeks ago you dont believe he really knows anything. The very same one that seems to have solved a couple Barco issues for others that no one else could ( or would, surely someone else knew the answer... )
Not only would i do that if indeed i had another one spare, but im thinking of trading the Barco on a 4600...
gregstv
Posted: Sun Jul 12, 2015 11:43 am    Post subject:
Case, I have 2 XG's, ( 1 x 1350 and 1 x 75), spare tubes and quite a few spare boards. more than happy to swap for the Cine 9. Very Happy
Posted: Mon Jul 13, 2015 8:21 am    Post subject:
Yeah, but yours have known issues!
gregstv
Posted: Mon Jul 13, 2015 8:28 am    Post subject:
But only one does. I am sure its nothing you couldn't fix. Last tmie I checked the 75 was fine.
Posted: Tue Jul 14, 2015 9:37 am    Post subject:
Yep, fair chance i could fix it, given the time. I have recently started a new career and have no real spare time to be doing much of anything else. I have recently ceased all video game and arcade machine repairs and mods, and id expect itll be at least 18 months before i resume any normal activity.
gregstv
Posted: Wed Jul 15, 2015 7:04 am    Post subject:
It just comes on a bit green. I think its only the green tube. It takes 15 to 20 minutes to settle. Its a shame as the tube has no burn in at all. Don't you have a spare green tube?
Posted: Thu Jul 16, 2015 9:29 am    Post subject:
Not a wear free one, but i have a couple worn ones. If you reckon the Barco has that much better an image over the XG id say there is more wrong with it than just the green tube.
Its irrelevant anyway, im far too busy.
gregstv
Posted: Thu Jul 16, 2015 10:50 am    Post subject:
If you believe so
Posted: Fri Jul 17, 2015 8:56 am    Post subject:
I do indeed, i know what my XG852 LC can do, and its not far behind my Cine 9. I can get scanlines visible clearly at 1080p, and its ultra sharp.
