BG1209/2, flickering brightness at startup and H size drift
winny
Posted: Tue Jun 30, 2015 10:41 am    Post subject: BG1209/2, flickering brightness at startup and H size drift
New problem since last week, there is a flicker in brightness when I turn on the projector from cold. Both input signal and generated menues are affected. I will try to capture a video of it. I would say all three tubes but I'll get back in that regard.
At the same time, H size has started to drift quite a lot. Normal geometry and convergence drifts perhaps a few percent from cold to hot but H size I need to adjust from 71 down to 52 to keep the width. This wasn't the case a few weeks after I replaced the H board.
Once the projector is hot there are no problems.
The problems came at the same time. Same or two different problems? Suggestions?
Melifluonze wrote:
barclay66
Posted: Tue Jun 30, 2015 12:04 pm    Post subject:
After warmup (when the problems have ceased), You could try freeze spray (I use Freeze 75 from this brand: http://www.kontaktchemie.com/KOC/KOCdefault.csp). Spraying onto hotter parts in the SMPS, the H board and maybe the Video switcher/driver boards could reveal the location of the problem...
Regards,
barclay66
Posted: Tue Jun 30, 2015 2:08 pm    Post subject:
It can really only be the SMPS or H output board. I've never seen H size drift before though, so I can't narrow it down any more than that.
Posted: Wed Jul 01, 2015 5:10 am    Post subject:
Examine the boards close up, check the solder joints
winny
Posted: Wed Jul 01, 2015 12:02 pm    Post subject:
Thanks! I'll get some freeze spray and test the H board and SMPS.
Here is a video:
https://www.youtube.com/watch?v=IqOjpuOz70A
It flickered less than usual but you can still see the problem.
Melifluonze wrote:
Posted: Wed Jul 01, 2015 4:51 pm    Post subject:
It might be the HV splitter. Taking a guess here though.
gregstv
Posted: Wed Jul 01, 2015 8:36 pm    Post subject:
I would not freeze the HV splitter. Good chance it will bite you.
