RobbyRocketz
| Posted: Thu Jun 11, 2015 2:37 pm Post subject: 2143 Autocal Done....... |
Autocal just finished and the calibration report just popped up on the screen.
How do I save the calibration into memory, or does the 2143 automatically save it for me?
Also, I've chosen the 21 point grayscale adjustment option, but how do I change the ire, won't move from 100ire.
The actual rgb adjustability works but I can't change the ire window from 100ire too 95ire for example.
_________________ Panasonic 65VT60
Lumagen 2143
OPPO 103
XBOXONE
PS4
| Posted: Fri Jun 12, 2015 8:51 pm Post subject: Re: 2143 Autocal Done....... |
| RobbyRocketz wrote: | Autocal just finished and the calibration report just popped up on the screen.
The actual rgb adjustability works but I can't change the ire window from 100ire too 95ire for example. |
To save your calibration use the Lumagen remote:
MENU → Save → Save → OK → OK
If you don't save after making any adjustments a Lumagen power cycle will revert to the previous saved configuration.
You cannot move the point at zero IRE or at 100 IRE for a parametric grayscale. In practice you must have a point at the bottom and top of the luma range. You can increase or decrease the luma at zero and 100 IRE, but you cannot change their position because they must be at either end. all point between zero and 100 are parametric and can be moved to whatever gray level you wish to adjust.
