I've completely lost blue focus
Posted: Sun May 31, 2015 1:35 pm    Post subject: I've completely lost blue focus
I've changed the CLM and the FGM. Not sure where to go from there, and right now don't feel like running it down.
No change at all on the Static...
barclay66
Posted: Sun May 31, 2015 2:06 pm    Post subject:
Next thing I would swap would be the neck boards (e.g. switch blue with green) and maybe the HVPS. What happens if You swap all the blue cables (deflection, convergence, focus and HV) with the ones of the green tube?
Regards,
barclay66
Posted: Sun May 31, 2015 3:26 pm    Post subject:
Regards,
barclay66
So far, I've swapped neck boards, and have only checked that the proper focus yoke is connected to the right place on the FGM.
Now I'll swap the connectors between the red and green focus coils and see what happens
Posted: Sun May 31, 2015 3:32 pm    Post subject:
Thumbs Up
That did it. It's the blue focus coil. A wire must have come loose inside of it
Posted: Sun May 31, 2015 4:12 pm    Post subject:
Wow, that's unusual. Never had that happen before.
Posted: Sun May 31, 2015 4:37 pm    Post subject:
Me too Curt, and that's why I didn't consider it before
barclay66
Posted: Sun May 31, 2015 4:38 pm    Post subject:
That's possible when You do as much testing and board removal/reinsertion as Mike does...
