NEC PG with F8 error code
Posted: Sun May 17, 2015 12:44 pm    Post subject: NEC PG with F8 error code
I gave away my old PG that was working normally when I took it down to put up my 4600HD. It has been in a dry closet, wrapped in a blanket for many years until I decided to give it away F8 seems to be a convergence related error. Any idea what to look for? He's a techie and will be able to fix it if he knows where to look.
Posted: Sun May 17, 2015 1:31 pm    Post subject:
Yes, for first try he should remove the power connector (CP) of the C-drive board. BUT the biggest question whether that NEC is still running on the original capacitors, if so, no reliable service is expected unless ALL electrolyte capacitors are changed!
Posted: Sun May 17, 2015 5:09 pm    Post subject:
Hanging on the point board and as luck would have it, he had a spare. He's doing the setup as we speak.
Posted: Mon May 18, 2015 4:40 am    Post subject:
If he doesnt replace those caps it wont last long, they leak due to age...
the big E
Posted: Fri May 22, 2015 5:51 am    Post subject:
Case is right
I went through that once with my pg(love the pic quality though)
I hope I don't go through it again unfortunately I need a c drive board(mine got broke in shipping)
crt king of black
Posted: Fri May 22, 2015 8:09 am    Post subject:
Repair that broken one!! Theyre a very basic board by todays standards
the big E
Posted: Fri May 22, 2015 2:14 pm    Post subject:
Ain't had the time yet mate
As it is the boards are still in my home theater as I haven't had time to pack them
To my workshop to even put them in my nec
Going to set in on them soon as I want to see it working again
crt king of black
