ChromaPure Tripod Extension
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    CurtPalme.com Forum Index -> ChromaPure Products
Posted: Mon Apr 27, 2015 12:54 am    Post subject: ChromaPure Tripod Extension
Order today at an exclusive CurtPalme.com reduced price! GO »
For some time we have been looking for a simple, inexpensive product that would enhance the user's ability to precisely place a Display 3 PRO (or other meter) that has been mounted to a tripod. This ChromaPure Tripod Extension fits the bill exactly. The perfect addition to any calibration toolkit!
Flat panel Readings
It is very common to have a flat panel installed in a location that is recessed from available floor space, which prevents one from placing a tripod mounted Display 3 PRO at a proper distance from the screen. The ChromaPure Tripod extension makes this very simple:
The extension arm is very light weight, yet sturdy and it extends the meter up to 3.5 feet forward from the base of the tripod. In the example above we are able to place the Display 3 PRO about 6 inches from the plasma screen with great precision in the vertical and horizontal planes. For larger and heavier color analyzers we also offer a heavy duty version of the Tripod Extension.
Front Projector Installations
If you have a ceiling mounted front projector there may be times where you want to read directly from the lens. This has always been difficult with ceiling mounts because tripods are generally not tall enough to provide the necessary height. The ChromaPure Tripod Extension solves this problem:
With the additional three-and-a-half feet of vertical extension at your disposal, even smallish tripods now will work fine for this task.
The ChromaPure Tripod Extension (standard version) is now included for free with the purchase of a ChromaPure Display 3 PRO bundle or Display 3 PRO auto-calibrate bundle. It is also sold separately.
Two sizes are available: Standard and Heavy Duty.
For complete details see our order page here: http://www.curtpalme.com/ChromaPure_Tripod_Extension.shtm
Posted: Mon May 04, 2015 3:38 pm    Post subject:
I'm ordering one now Kal.
Posted: Mon May 04, 2015 7:55 pm    Post subject:
Thanks for the order Craig! Let us know how you like it.
Posted: Mon May 04, 2015 8:37 pm    Post subject:
This extension seems like it might be the perfect thing to compliment the tripod that comes with the Specbos. Their tripod folds down to an incredibly small size for easy transportation, but it does not have a height adjustment (other than lowering with the three legs) and the tripod is often not tall enough. This extension looks just as portable and should fill in the shortcomings of the OEM tripod.
I'll let you know how I like it when it comes.
Thanks Kal,
Posted: Tue May 05, 2015 7:06 pm    Post subject:
Looks like with the right attachment on the end, it might do double-duty as a selfie-stick. Smile
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    CurtPalme.com Forum Index -> ChromaPure Products All times are GMT
