Version 3.0
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    CurtPalme.com Forum Index -> ChromaPure Products
Ron W
Posted: Wed Apr 22, 2015 7:59 pm    Post subject: Version 3.0
Back in December/2014, it was announced that the "spanking new version 3.0" was to become available first quarter of this year. Still haven't seen any signs of it yet or a description of the new features.
Any updates?
TomHuffman
Posted: Wed Apr 22, 2015 8:06 pm    Post subject:
The release date slipped a little. I hope to have it out in 4-6 weeks.
ChromaPure calibration software & meter packages at CurtPalme.com discounted prices!
grifo
Posted: Tue Jun 02, 2015 3:16 pm    Post subject:
Nothing yet??
projector: Sony vw1100es; main tv: Pioneer KRP600A; other tvs: Philips pfl 556008 and
pfl 376007
Home automation & Lighting control: Crestron & Lutron
AV distribution: Athlona
power distribution: Showtec psa-161
Audio: pre: Ada Cinema Reference Mach IV ampli: Ada PTM 5150 x 2
room correction: Trinnov 16 ch.
loudspeakers: ​Klipsch thx ultra 2 customized cables:Sigma Cableless
source: Digifast, Oppo 103eu, mysky hd x2 Video: video processor: Lumagen Radiance 2041 calibration: Chromapure with advanced auto calibrate and X-rite eyeone display 3 pro
screen: Screen Research electric 4 masks ac. transparent 4k 16/9 3,30 mt gain 1.0 customized
remotes: ​ipad mini, ipad air, iphone 5s
RobbyRocketz
Posted: Tue Jun 09, 2015 11:04 pm    Post subject:
Will it still have 21 point gamma and grayscale autocal capability?
Its the reason I purchased the 2143 processor.
Panasonic 65VT60
Lumagen 2143
OPPO 103
XBOXONE
PS4
Posted: Tue Jun 09, 2015 11:10 pm    Post subject:
I think it's safe to say that functionality will not be removed, only added/expanded. Otherwise nobody would want to upgrade.
Gudi
Posted: Wed Jul 01, 2015 7:20 am    Post subject:
Just to clarify, is the current Display 3 PRO in stage 2.0, and we're waiting for stage 3.0?
Posted: Wed Jul 01, 2015 2:53 pm    Post subject:
Can you clarify what you mean? ChromaPure 2 is the current version of software that is offered. Version 3 is on the way and for some time now anyone who purchases today's version 2 will automatically get a free upgrade to ChromaPure version 3 once available.
This has nothing to do with meters such as the Display 3, or the enhanced version called the Display 3 PRO.
Both ChromaPure 2 and the upcoming version 3 will support the Display 3 and Display 3 PRO.
Posted: Wed Dec 30, 2015 8:14 pm    Post subject:
ChromaPure 3 is now available!
To download or order see here:
http://www.curtpalme.com/ChromaPure.shtm
Ron W
Posted: Thu Dec 31, 2015 7:32 pm    Post subject:
Just to clarify, since I originally purchased Chromapure back in 2011, yet, the license is listed as perpetual, I am assuming it will not be recognized during the import procedure until after I pay the additional fee. Correct?
Posted: Thu Dec 31, 2015 7:42 pm    Post subject:
Hi Ron,
Given that you purchased ChromaPure before Dec 17, 2014, you will not be able to use ChromaPure 3 until you pay the upgrade cost to have your licence file updated to v3. I'm assuming you're using Chromapure 2? There is no upgrade path from ChromaPure 1 to 3 given the age.
Ron W
Posted: Thu Dec 31, 2015 8:50 pm    Post subject:
Hi Ron,
Yep, I have version 2 updated to the most recent 2.5.8.
Posted: Thu Dec 31, 2015 9:00 pm    Post subject:
Then you're good to go. You have both v2 and v3 installed at the same time (just can't run both at the same time of course).
pompyto
Posted: Sun Jan 03, 2016 2:55 am    Post subject:
Hi. I upgraded to the new version Chromapure 3, but in my case it does not work under Windows 10 64 Bits.It reports that the program is not supported.
I could not update the Microsoft .NET Framework version 4.6.1 on Window 10 Pro because it comes preinstalled.
I tried to turn on file compatibility, changed language, region, etc., but still gives the same error.
It has happened to someone else or know how to fix it. Thank you
This is the error:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Collections.Generic.KeyNotFoundException: The given key was not present in the dictionary.
at System.Collections.Generic.Dictionary`2.get_Item(TKey key)
at System.Collections.ObjectModel.KeyedCollection`2.get_Item(TKey key)
at ChromaPure.Controls.MeterConfigControls.MeterSelectionList.AutoConnect()
at ChromaPure.Controls.MeterConfigControls.MeterSelectionList.MeterSelectionList_Load(Object sender, EventArgs e)
at System.Windows.Forms.UserControl.OnLoad(EventArgs e)
at System.Windows.Forms.UserControl.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.ControlCollection.Add(Control value)
at ChromaPure.Controls.TabControl.TabStrip.OnCollectionChanged(Object sender, CollectionChangeEventArgs e)
at ChromaPure.Controls.TabControl.TabStripItemCollection.OnCollectionChanged(CollectionChangeEventArgs e)
at ChromaPure.Controls.TabControl.TabStripItemCollection.OnInsertComplete(Int32 index, Object item)
at System.Collections.CollectionBase.System.Collections.IList.Add(Object value)
at ChromaPure.Controls.TabControl.TabStripItemCollection.Add(TabStripItem item)
at ChromaPure.Controls.TabControl.TabStrip.AddTab(TabStripItem tabItem, Boolean autoSelect)
at ChromaPure.Controls.TabControl.TabStrip.AddTab(TabStripItem tabItem)
at ChromaPure.frmMain.AddTab(String title, Control control, Bitmap img)
at ChromaPure.frmMain.AddHomeTab()
at ChromaPure.frmMain.frmMainNew_Load(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.6.1063.1 built by: NETFXREL3STAGE
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
ChromaPure
Assembly Version: 3.0.2.41690
Win32 Version: 3.0.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/Display%20Calibrations%20LLC/ChromaPure3/ChromaPure.exe
PresentationCore
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
WindowsBase
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
System.Core
Win32 Version: 4.6.1038.0 built by: NETFXREL2
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
CpHw
Assembly Version: 3.0.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/Display%20Calibrations%20LLC/ChromaPure3/CpHw.DLL
CpColorScience
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/Display%20Calibrations%20LLC/ChromaPure3/CpColorScience.DLL
CpL
Assembly Version: 2.0.0.0
Win32 Version: 2.0.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/Display%20Calibrations%20LLC/ChromaPure3/CpL.DLL
System.Deployment
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Deployment/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Deployment.dll
System.Deployment.resources
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Deployment.resources/v4.0_4.0.0.0_es_b03f5f7f11d50a3a/System.Deployment.resources.dll
System.Xml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
Microsoft.GeneratedCode
WindowsFormsIntegration
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll
PresentationFramework
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
System.Xaml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
mscorlib.resources
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_es_b77a5c561934e089/mscorlib.resources.dll
PresentationFramework.Aero2
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero2/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero2.dll
PresentationFramework.resources
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.resources/v4.0_4.0.0.0_es_31bf3856ad364e35/PresentationFramework.resources.dll
Microsoft.Expression.Drawing
Assembly Version: 4.5.0.0
Win32 Version: 3.0.40218.0
CodeBase: file:///C:/Program%20Files%20(x86)/Display%20Calibrations%20LLC/ChromaPure3/Microsoft.Expression.Drawing.DLL
PresentationFramework-SystemXml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXml/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXml.dll
UIAutomationTypes
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/UIAutomationTypes/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationTypes.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
pompyto
Posted: Sun Jan 03, 2016 1:51 pm    Post subject:
Thanks Tom for help me so fast.
Apparently there was an error in the license file and not working. With the new license starts well, soon to see if I can prove good.
A greeting.
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    CurtPalme.com Forum Index -> ChromaPure Products All times are GMT
