Barco cine9 1080p50
tanwn1
Posted: Thu Apr 16, 2015 2:35 am    Post subject: Barco cine9 1080p50
i can display 1080p60 but can't view 1080p50 on my cine9, I have a moome v3, do i need to do a jumper switch to enable some sort of neg sync like that? By the way i can view both 1080p60 and 50 on my sony g70 via the moome v3.
Posted: Thu Apr 16, 2015 2:48 am    Post subject:
Shouldnt be an issue, i can do it with mine.
Change the jumper inside the V3 as recomended in the .pdf
redfox001
Posted: Thu Apr 16, 2015 7:33 am    Post subject:
Perhaps shifting the image horizontal with the button on the moome. The timings for 50 are very big.
ElTopo
Posted: Thu Apr 16, 2015 5:28 pm    Post subject:
Why 50 Hz ?
Barco Cine 9 the one and only
tanwn1
Posted: Thu Apr 16, 2015 11:20 pm    Post subject:
ElTopo wrote:
Why 50 Hz ?
Just so happen that i have one "corrs unplugged dvd" recorded in PAL land and would like to view it in its native 50hz format. I can switch to 60hz using my oppo no problem. But still can't view it in 50hz even after shifting the image and changing to neg sync on moome v3, not exactly sure why.
Posted: Fri Apr 17, 2015 12:26 am    Post subject:
I have that same DVD.
No good reason it wont work at 50Hz, but youre using an OPPO, set the output to 60Hz, makes no difference when youre watching a Corrs DVD, just saves a heap of f***ing around.
