Barco 808s Vertical Height Adjustment - need more adjustment
barco_75
Posted: Sun Mar 22, 2015 11:39 pm    Post subject: Barco 808s Vertical Height Adjustment - need more adjustment
Hi, I am trying to reduce the height of my image at 1080i 60 hz and 1080p 60 hz. I have the Vertical height setting at the lowest value 0, and it is not enough. My Horizontal width is set at 68. I'm thinking I need to adjust the master width pot (following link below) on the SMPS so at 1080p, my horizontal width is 95 and ignore the 48V reading. Will this work? Do I need to need to readjust the 17.2V reading on the J8 test point on the SMPS after adjusting? Does adjusting the master horizontal width affect the 17.2 reading? I never quite understood this. Below is the resource that I have followed before but never quite understood 100%
https://www.curtpalme.com/forum_archived/viewtopic.php@t=33016.html
Also, I recently bought a DVDO VP50 pro and I was going to use the processor to shift the image (due to the HDFury 1 shifting the image) instead of using the projector raster shift. Is this preferred? I think this will give me more adjustment with the convergence, correct?
barco_75
Posted: Mon Mar 23, 2015 12:37 am    Post subject:
Well, I tried that adjustment on the master width pot. That didn't help. One item to note is that I switched MEC tubes to Sony tubes to change my 808 to an 808s, which explains why this is an issue. Guessing there is another pot I need to adjust for the master vertical height.
Update: I just found this:
From the Barco FAQ at http://www.crtprojectors.co.uk/
"Projectors fitted with the optional convergence on green module may not be able to lower vertical amplitude far enough to reach anamorphic (problem normally occurs on 808s models). Remove the convergence sub board to solve the problem, if you must keep the convergence on green module set the 2 green zones above and below the central one to lower vertical height as far as possible, this may get you to true anamorphic height but is not the ideal way to have the projector set-up."
I have a convergence on green card. I only have one projector. Is there another way to adjust the vertical height or do I need to remove the convergence on green card?
Posted: Mon Mar 23, 2015 4:41 am    Post subject:
Yes, I can mod the vertical board for $125 incl return shipping to bring your height down to what you need it to be.
barco_75
Posted: Mon Mar 23, 2015 4:06 pm    Post subject:
Thanks, Curt. I'm in the process of pulling the COG to see if that helps. I also notice this morning the disk I used wasn't 16x9, but was 1.85:1 so I might be ok depending in how the processor and blueray displays the image. Stupid, Stupid, Stupid me! In regards to shifting the image in the scaler or projector, is it recommended to use the scaler instead of the raster shift? Does this give more adjustment with convergence?
