Marquee: Image shifter module
UncleWill
Posted: Wed Mar 11, 2015 9:40 pm    Post subject: Marquee: Image shifter module
So, I understand the purpose of this thing and that it claims to reduce burn in. My question though:
Does any recommend this for HT use?
Is it a wise choice?
Has anyone had it in the past?
Posted: Thu Mar 12, 2015 2:30 am    Post subject:
Hello
The purpose is to move a static image, like a map, around some so it is less likely to burn in. It is pretty much useless for movies or tv
Posted: Thu Mar 12, 2015 3:06 am    Post subject:
It would work OK if you are gaming to not burn the gaming counters into the screen no?
Posted: Thu Mar 12, 2015 2:08 pm    Post subject:
The trouble is that if you use an image sifter (also called picture orbit by other manufacturers), the image will be incrementally moved around the screen. This prevents you from being able to optimize your projectors phosphors because if you do, when the image shifts, the corners will go off the face of the tubes. If you want to use a shifter/orbiter than you have to put the projector further back from the screen than you otherwise would have. You also have to use more overscan because if you don't, you will get a thin black bar on one or two sides at a time near the edges of the screen when the image shifts.
That said, if you know you are going to watch a lot of the same station and the station has a pronounced logo, the shifter can extend the amount of time you can view said station before the logo gets burned in.
Posted: Thu Mar 12, 2015 3:12 pm    Post subject: Re: Marquee: Image shifter module
I refer you to my old CRT sucks for gaming!!! thread.
If you don't game, use PC with static menus, or watch the same news channel for dozens and dozens of hours, you're probably fine. If you do any of those things, or especially if you have a game or sim with a static status display or other graphic elements, then it may be a good idea to use the shifter/orbiter.
I never noticed the pic orbit function on my G70 moving the image that much, so I didn't think it would really have any effect on running the rasters to the corners of the tube. From recollection, it was only moving the picture an inch or so in any direction on my 8-foot wide screen, so we're probably talking 1/16" or maybe 1/8" that on the tube face. So, unless you're running a huge screen, or unless you're running the rasters right to the edge of the tube, then I can't see how it would be a problem. I left about 1/4" in the two close corners when I set up my G70 because I didn't want to deal with corner focus and geometry problems the people who running their rasters too large were having.
My experience is with the G70, so I don't know about the Marquee module. Try it and see what it does and how much it moves the picture.
Just my .02.
Cheers,
