Barco Cine 8 splitter
dentree
TV/Projector: BARCO GRAPHICS 808 BARCO GRAPHICS 801
Posted: Thu Feb 19, 2015 9:33 am    Post subject: Barco Cine 8 splitter
Has anyone out there got a spare barco splitter to suit the Barco Cine 8
Currently I have the Quad numbered R762717 also EHT number R7627165
I have 2 splitters here, but the numbers do not marry up with the BARCO bulletin requirements for new frame parts
The splitters I have here have the following numbers on them: 7617447 / 5 and 7617447 / 2
Many thanks
Posted: Thu Feb 19, 2015 3:30 pm    Post subject:
Use either of the splitters, they are identical electrically throughout the Barco series (except for the very old BArco 400/600) regardless of the part number.
Posted: Thu Feb 19, 2015 11:54 pm    Post subject:
Hulio had a descrepency with that earlier...
Hulio
Posted: Fri Feb 20, 2015 3:48 am    Post subject:
I didn't. Barco did when they put in that service bulletin: old splitter + new EHT + new quad + new frame = oscillation.
If the splitters are all same, than it seems like Barco put different part numbers just so they could charge more for them Shocked
Posted: Fri Feb 20, 2015 6:57 am    Post subject:
No worries Wink
Posted: Fri Feb 20, 2015 7:07 am    Post subject:
All of the splitters inclusive of the 800 series and beyond seem to be interchangeable. I think we have already covered this.
dentree
Posted: Fri Feb 20, 2015 12:55 pm    Post subject: Barco Cine 8 splitter
just reporting back in regard to the splitter, all is working, been running for about 6 hours now no smoke, no excessive heat, no fireworks of any kind.......so far, Curt the Guru is most certainly right in his assessment of the splitter situation, but conflicting official BARCO service bulletin information can certainly be a recipe for paranoia to a novice, so it would seem that "In curt we trust" ( seem to remember that as a biblical quotation.....can't remember the fellas name though) Smile
Anyway for Hulio, I imagine that you will be glad to hear everything so far is good and things seem to be coming together.
Trev
Posted: Fri Feb 20, 2015 2:46 pm    Post subject:
Oh, I didn't mention.. it's in the SEVENTH hour that all hell breaks loose. Very Happy
(kidding!)
Hulio
Posted: Fri Feb 20, 2015 5:56 pm    Post subject:
Sweet. Let's hope it stays like that. Post some screenshots when you have time.
Curt, you devil....
Posted: Sat Feb 21, 2015 12:03 am    Post subject:
Dont you mean the seven thousanth hour Curt???
dentree
Posted: Sat Feb 21, 2015 2:06 pm    Post subject: Barco Cine 8 splitter
Hulio, Casey, Curt, or whoever,
You mention the "so called inconpatibility" memorandum in the Barco bulletin, in particular with reference to:
old splitter + new EHT + new quad + new frame = oscillation. what would I be seeing in terms of oscillation
For instance what would it look like on say...Rolling credits, would I see like a vertical wave motion as the text rolled up the screen?
Trev
I am just trying to find out if I have got this disease.
Hulio
Posted: Sun Feb 22, 2015 6:15 pm    Post subject:
Not sure how that oscillation will behave in terms of picture quality Trev. In electronic components, oscillation means fluctuation above and under a nominal value. Since all ( or almost all ) splitters have the same construction, my theory is that the only difference could be in the treshold that potmeter on the splitter is set at. It's a factory preadjusted pot and gives feedback to the EHT ( trough that thin white wire ) how much power has to be generated.
But again, it is just a theory. Since others with a lot of practical experience in parts interchangebility did not encountered any problem at all, maybe is is safe to say that the so called oscillation does not harm the projector.
Maybe those vertical waves motions have to do with something else. On AC machines, people often are complaining about streaking during white rolling credits on a black background.
