crt display
Joe Patino Jr
Posted: Wed Feb 04, 2015 7:13 am    Post subject: crt display
Curt, or anybody that can answer this question. How far back must a crt. proj. be to be able to display an 120" dia. image? proj. either an Sony g90, or marquee 9500 ultra. joe P.
run faster, death is gaining on you
Posted: Wed Feb 04, 2015 10:28 am    Post subject:
Around 4 meters. Let me check mine.
Posted: Wed Feb 04, 2015 10:30 am    Post subject:
Its closer to 3.6 meters with HFQ900 lenses.
Thats assuming a 16:9 screen, 4:3 will need to be a bit further back. Say between those two figures.
Posted: Thu Feb 05, 2015 3:22 pm    Post subject:
Typically 1.35 X the width of the screen, regardless of aspect ratio used.
Posted: Sun Feb 08, 2015 11:26 pm    Post subject:
My 9500LC is almost exactly 120 inches from screen to center of center lens, as measured across the floor, so given the slight angle of the projection, actual path of travel from the center of the green lens to the center of the screen will be a little bit longer than that, maybe one extra foot at most. This is for an 8 foot wide screen.
Lens type is HD10GT17. Rasters are well maximized without any fold-back.
Posted: Mon Feb 09, 2015 1:41 am    Post subject:
Dont you widen the raster for 16:9?
