Does a Lumagen HDP upconvert from analog video to DVI?
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    CurtPalme.com Forum Index -> Lumagen Products
Posted: Sat Dec 27, 2014 4:04 pm    Post subject: Does a Lumagen HDP upconvert from analog video to DVI?
I feel kinda dumb asking this, but I've never done it before...
Does the Lumagen HDP upconvert to the DVI output from the analog inputs?
thanks!
HogPilot
Posted: Sat Dec 27, 2014 4:12 pm    Post subject:
Absolutely - it will also convert digital inputs and output them via analog, as long as the original digital signal wasn't HDCP protected. See more in the user's manual here.
Posted: Sat Dec 27, 2014 4:18 pm    Post subject:
OK, thanks!
Posted: Sun Dec 28, 2014 4:48 am    Post subject: Re: Does a Lumagen HDP upconvert from analog video to DVI?
thanks!
Be sure you have enabled DVI out as it can be turned off. So if you get nothing from the DVI port thats probably the case. You enable output to either DVI or RGBHV or both.
What Lumagen are you using as my experience is only with PRO HDP and the HDQ
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    CurtPalme.com Forum Index -> Lumagen Products All times are GMT
