To space or not to space...
Melifluonze
TV/Projector: 9500LC Ultra
Posted: Thu Nov 06, 2014 4:21 am    Post subject: To space or not to space...
I took the HD-10L's off of two projectors... One has little spacers and one doesn't.
What is correct? Spacers between the lens flange and C element ring or no spacers???
-M
Posted: Thu Nov 06, 2014 3:51 pm    Post subject:
Hello
Never seen spacers, must be shims to enable closer focus
Melifluonze
Posted: Thu Nov 06, 2014 4:04 pm    Post subject:
Could be. They look like little washers around the hex cap screws that hold the lenses on. They reside between the lens flange and the C-element mounting ring. It looks like they have some kind of slow sticky adhesive on them so that they stick while the lens is mounted.
I wonder if spacing the lens out allows for a larger screen to be focused with the HD-10L?
- M
Posted: Thu Nov 06, 2014 4:13 pm    Post subject:
Why dont you try with and without spacers, and see how the focus and trow look like ?
If it works for better corner focus or different trow it might be a interesting tweak.
ElTopo
Posted: Thu Nov 06, 2014 6:26 pm    Post subject:
Never had spacers.
HD-10L are sharp corner to corner without them.
Barco Cine 9 the one and only
Melifluonze
Posted: Fri Nov 07, 2014 4:02 am    Post subject:
Ok. Going to try both ways to see while setting up the stack.
-M
