Substitute ButtKicker Amp
AFryia
Posted: Sat Sep 27, 2014 2:05 pm    Post subject: Substitute ButtKicker Amp
I tried and failed to repair my BKA1000-4A ButtKicker amplifier.
Rather than go with another BK amp Mad are there any known substitutes.
Posted: Sat Sep 27, 2014 6:39 pm    Post subject:
For Buttkickers? Grab any old decent used amp on craigslist or ebay. Ebay has lots of great amps available. I was always pretty fond of the monoblock Marantz MA500, or its big brother the MA700. There was also a newer version of the MA500, the MA6100. I was going to go with (6) MA500's before I decided to go with more powerful Crown pro sound amps.
AFryia
Posted: Tue Oct 14, 2014 12:20 am    Post subject:
From what I can gather the MA6100 is 125W.
The LFE transducer is rated 400W @4ohms. I'm sure that amp would work, but wouldn't it be underpowered driving <20hz, even with a pair bridged?
My Volt Blog
Posted: Tue Oct 14, 2014 3:45 am    Post subject:
Yeah, probably a little underpowered. Depends how many transducers you have and how hard you want to drive them. How many transducers do you have? Do you listen pretty loud?
Posted: Tue Oct 14, 2014 3:48 am    Post subject:
Yeah, seal the cabinet back and get an external power amp. Find something that's bridgeable, and get a 100-150 WPC channel power amp. Bridge it in mono, and you'll get about 400 watts at 4 ohms. Also keep in mind that the power rating of the woofer is going to be a bit ambiguous, but based on your info, what I stated above should work.
Otherwise, with the price of used powered subs out there, you may be cheaper getting a used powered sub, and scrap the Buttkicker.
Posted: Tue Oct 14, 2014 3:52 am    Post subject:
BTW, the Behrenger iNuke is probably about as cheap as class-D sub amplification gets. It's larger than the BK amp, but a little more flexible. They're a little over-rated, and they have fans, but they're still a great value. Lots of guys use them as sub amps.
Cheers,
Posted: Tue Oct 14, 2014 3:54 am    Post subject:
Wrong thread, Curt. Wink
Posted: Tue Oct 14, 2014 4:07 am    Post subject:
No, not the wrong thread. He needs a replacement amp. What I missed is that it's a transducer.. wasn't thinking along those lines. Smile
The only thing that might be an issue, is that I've had nothing but issues driving the Aurasound transducers with a 'regular' car stereo amp.. 3 or 4 different ones would go into protect mode all the time. I finally figured out that the Aurasound impedance was insanely low, so I series-ed two of them, and then the car amps worked well. Not sure if the Buttkickers have the same issue, but I'd drive the transducer carefully while monitoring amp temperature before driving it hard.
For my money, I wouldn't get anything by Behringer. Cheapest crap ever! If you have rack room, get a QSC or Crest power amp, bridge it mono, and you're done.
I'm also done recommending Crown after the fiasco I've had with their cheap crap on a local jobsite.
Posted: Tue Oct 14, 2014 4:33 am    Post subject:
QSC......QSC...... ha, I sound like I'm cheering a college. And get an older one at that, like an MX series. Here is an example: http://www.ebay.com/itm/QSC-MX-700-Stereo-Power-Amplifier-MX700-Amp-/171391754201?pt=US_Pro_Audio_Amplifiers&hash=item27e7be9fd9
700 watts, bridged mono into 4 ohms. Nice clean power and silent fan.
Posted: Tue Oct 14, 2014 4:52 am    Post subject:
Only reason I mentioned the iNuke is that a lot of guys on AVS use them as sub amps with great success. Like I said, they're over-rated, but still a very good value. They're not pro-quality and won't last running 24/7 in a commercial environment, but when most of us use our theaters like 4-8 hours a week, build quality and longevity isn't as big of a concern as it might be in your line of work.
I know you said that, and I'm sure the new stuff isn't as solid as it used to be, but I and a few friends have had very good luck with our Crown XLS202/402/602's. Mine ran in my theater for years, and I think I'l probably pick up a couple more to try Atmos. Might also try a couple of the QSC's that Mac recommended for sub amps. Wink
Posted: Tue Oct 14, 2014 2:16 pm    Post subject:
I have a client that has 16 Crown CTS 4200s. Air conditioned room that sits at 62 degrees, background music and paging. Massive 140,000 sq ft store, 64 zones of audio. They have had 8 amp failures in 7 years. One happened to fail when I was there. I had to power them all down to change the firmware in their DSP, and one amp refused to come back on. Manager said that this was the same problem they have had every time.
They used to send it to Crown in Canada (Soundcraft) for repair, at 2 months (!!) and $400 later. I asked the manager to email me the bill of the last repairs, so I could see what the issue was. He did... 'LV power supply replaced' I thinks to myself 'WTF???'
So I saw exactly the issue once I opened the unit. These Crowns use a little kickstarter power supply for some stupid reason at turnon to power the main amp up. the main amp is a nice fibreglass PC board, but the little LVPS is on a separate board, bolted inside of a shield, and the build quality is that of a laptop power supply. Phenolic board, total cheap build quality. Of course all the main power supply caps had the bottoms popped off. Soundcraft kept putting replacement POS power supplies into the unit, which of course would result in a repeat failure. I put in Panasonic caps.
I have quoted the customer on replacement amps.
I have had zero failures with the Crest amps, and a buddy/semi competitor says he's had zero failures of QSCs as well. Mac's recommendation of an MX700 is a good one, although those amps are now 20+ years old. I've seen a few through here (along with the larger 1500s) that were driven hard and put away wet, and more than one had big heat damage on the PC board, with open capacitors on the boards.
BUt, there's a bunch of options to consider in this thread. Smile
Posted: Tue Oct 14, 2014 2:42 pm    Post subject:
And what is wrong with being 20+ years old? Must I direct you to an old thread on capacitors, lol. Laughing 20 year old stuff is better then new, 3, 5 and close to 10 year old stuff and the 20 year old will still outlast them.
Posted: Tue Oct 14, 2014 2:54 pm    Post subject:
Except when you buy something 20+ years old and it's not working right, like the Adcom GFA amp I bought that had a huge DC offset on one of the outputs. Could easily have killed one of my main speakers if I hadn't yanked the banana plugs. No big deal if you're a tech, but a big hassle if you're not.
Posted: Tue Oct 14, 2014 3:35 pm    Post subject:
But I did not recommend Adcom. Also, now your talking a failed amp. And how much DC was there? Did it have protection? How did you test it? What was wrong with it?
I don't expect you to answer any of those questions. Just making a point of how non relevant your response was.
Very Happy
Posted: Tue Oct 14, 2014 4:49 pm    Post subject:
I realize you didn't recommend Adcom, but I think it's absolutely relevant to consider that older used equipment can be broken, have major issues, or even just not operate to spec - whether it's the Marantz I recommended or the QSC you recommended. Yes, you can return broken gear to a seller for a refund, but it's a hassle. You can do the same with new gear, too. My point is that buying used equipment can be especially risky - especially for us non-techs. You don't perceive that risk the same way the rest of us do because you can fix damn near anything, but that doesn't mean the risk isn't there.
To answer your questions, it's been a long time, but I believe there was like 40+ volts on the right channel. How I tested it? A VOM across the speaker outputs. The right channel DC offset was huge, while the left channel was practically nonexistent. I found out about it when I heard a huge crack sound out of one of my speakers. Lesson learned. Check used gear over before you plug it into other gear. I asked about the issue here, and there were several possibilities given, including a blown output transistor. It sounded potentially pretty involved, and I wasn't interested in investing the time into it, so I sold it to another member for a half or a quarter of what I paid. So, I don't know what was wrong with it. It was my fault for letting it sit for several months before I tested it. Even though it was highly likely already borked when he listed it, it could have developed that issue in transit, or it could have developed the issue when I plugged it in. I couldn't go back to the seller at that point.
Posted: Tue Oct 14, 2014 5:00 pm    Post subject:
Mac, only because many of the QSCs have been driven hard. They weren't marketed towards HT users, they were marketed towards pro stuff. Heck, those lemon Crown amps will be fine if I get my hands on them as trade-in, I'm recapping the LVPS with better caps, but any amp that's been put through the wringer by a band or a club (all clubs were smoking establishments back then), it may have internal issues.
Also as an FYI, the QSC 1500 non 'a' series had a basic design flaw. The DC return to ground for the preamp op amp ran through the main level pot. Once the level pot went noisy, guess what happened? Hit an oxidized spot on the control, and the output would momentarily go to full DC. Had a number of 1500s used to drive mid-high cabinets in clubs back in the day, and had more than one cabinet come in with a blown driver. It wasn't until one club brought in one of the QSC 1500s and said 'the horn popped when I adjusted the level control' that I figured it out. I let QSC know, and the tech I talked to had a shitfit. The 1500a had the problem cured.
Not sure if that issue was with the 700 as well.
Posted: Wed Oct 15, 2014 12:02 am    Post subject:
I actually own a MX1500 and an MX1000. I also have a 1000a. Those level pots are suppose to be set at full and left there. Any pot will go erratic over time. All this talk is non relevant. New stuff can fail just the same and probably worse then old. Brand new amps can take out drivers. I still work on pro stuff all the time. I have multiple Dj's and some local bands that bring me their stuff for repair. At this point I do not even know what you and SC are trying to recommend. I could easily trash any make or model that can be thrown out here. So I only recommend what I know from my own experience of which makes and models would be the best option. Would I recommend a QSC after the USA series, probably not. Do you see my point?
I could take everything both of you said and turn it to any make or model, new or used. I'm saying, if you threw all these pro amps into a big pile, I am weeding through the pile to say what the best value is that I have found after all these years.
But lets look at it this way. When someone who is an expert in repairing this stuff and can choose what ever brand he wants tells you what he is personally using in 1 of his own setups, what would be some thoughts.
So really guys, do you have recommendations or just looking to trash others recommendations?
AFryia
Posted: Wed Oct 15, 2014 12:59 am    Post subject:
At present i have a single LFE transducer.
With iNuke or QSC etc. those are full range amps right. Can they sustain the bottom end running 15hz signals for periods of time?
I've also been contemplating sub plate amplifiers.
http://www.parts-express.com/dayton-audio-spa500-500w-subwoofer-plate-amplifier--300-807
No fan and built specifically for sub and infrasonic range.
