RCA line level to Mic adaptors?
Posted: Tue Sep 02, 2014 11:00 am    Post subject: RCA line level to Mic adaptors?
I need a couple of RCA line level to 1/8" mono mic adaptors. Radio Shack sold them for years but no longer list's them. Anyone know of a piece that fits the bill?
Posted: Tue Sep 02, 2014 3:25 pm    Post subject:
http://www.monoprice.com/Product?c_id=104&cp_id=10429&cs_id=1042902&p_id=7146&seq=1&format=2
Didn't find them just browsing Monoprice, but when I googled "rca 3.5mm adapter mono", that was the first hit. They're also on Amazon, CablesToGo, Parts Express, etc.
http://www.parts-express.com/rca-jack-to-35mm-mono-plug-adapter--090-288
Posted: Tue Sep 02, 2014 5:26 pm    Post subject:
Thanks SC, but those are just passive adaptors. The ones I use to see at RS had some electronics in there to adapt the signal levels. they were about 2 inches long and red in color.
Posted: Tue Sep 02, 2014 5:28 pm    Post subject:
So, they took a line-level RCA output and adapted them to a 3.5mm microphone input? What's the use case?
Posted: Tue Sep 02, 2014 5:36 pm    Post subject:
In my case I have a mixing board that has 4 mic inputs, and only RCA line level outputs.
My other thing could be to find an external USB sound card with RCA line level inputs OR a pair of adaptors and a stereo mic input.
I have two high end sound cards here from the HTPC days, not sure if they have the stereo mic inputs or not. I have to check.
I need to get some stereo audio into the PC for my Hallowe'en haunt. I want the voice to slide back and forth across the front of the house. Especially the maniacal laughter and the whispering. Twisted Evil
This was so easy when I recorded to tape...
Posted: Tue Sep 02, 2014 6:05 pm    Post subject:
I love collectors...
From page 129 of the 1986 Radio Shack bible:
 Filesize:  7.77 KB
 Viewed:  8936 Time(s)
 Filesize:  18.59 KB
Posted: Tue Sep 02, 2014 6:08 pm    Post subject:
Anyone got a time machine? Mr. Green
Posted: Tue Sep 02, 2014 6:11 pm    Post subject:
Just find a PMSing redhead. Mr. Green Thumbs Up
Posted: Tue Sep 02, 2014 6:32 pm    Post subject:
Jeremy, a simple resistor divider is inside that RCA-jack adaptor. Put an 1k Ohm resistor between the hot pin of RCA and TRS, and put a 10 Ohm resistor between the ground and the hot pin of TRS, and you get -40dB gain.
Posted: Tue Sep 02, 2014 11:40 pm    Post subject:
Thanks! I knew it was something simple. BUT! If anyone has a pair of these please let me know. I'll give them a good home and won't feed them after midnight. Very Happy
What does TRS stand for?? ( Tandy Radio Shack ) Laughing
Now on to my next post: http://www.curtpalme.com/forum/viewtopic.php?p=418084#418084
Posted: Tue Sep 02, 2014 11:56 pm    Post subject:
No, and HELL NO!
Posted: Wed Sep 03, 2014 6:06 am    Post subject:
TRS stands for Tip Ring Sleeve aka. phone jack.
I don't have any of these, I just reverse engineered. Thumbs Up
