larry9040
| Posted: Tue Aug 19, 2014 7:56 pm Post subject: Barco 908 |
Projector is displaying blue screen with horizontal lines. Already swapped convergence board, power supplies, rgb cards, as well as deflection cards. Any ideas?
| Posted: Tue Aug 19, 2014 8:00 pm Post subject: |
Post a pix?
larry9040
| Posted: Tue Aug 19, 2014 8:47 pm Post subject: BARCO 908 |
Will not be able to take a picture
| Posted: Tue Aug 19, 2014 9:18 pm Post subject: |
Well no offense, but your description is REALLY vague. But I'll try to assist.... does the internal test pattern come up normally? What input are you using? What signal is fed from what source, through what equipment, and into what input on the projector?
Are the horizontal lines straight across the screen or are they somewhat diagonal?
| Posted: Wed Aug 20, 2014 1:04 am Post subject: |
| Curt Palme wrote: | Well no offense, but your description is REALLY vague. But I'll try to assist.... does the internal test pattern come up normally? What input are you using? What signal is fed from what source, through what equipment, and into what input on the projector?
Are the horizontal lines straight across the screen or are they somewhat diagonal? |
Come on Curt. He just wants a solution and has no time
| Posted: Wed Aug 20, 2014 2:35 am Post subject: |
Pull it down and put up an NEC.
| Posted: Wed Aug 20, 2014 4:38 am Post subject: |
| CasetheCorvetteman wrote: | | Pull it down and put up an NEC. |
That's one solution
hansilili
Joined: 09 Mar 2007 Posts: 302 Location: Köln, Germany
| Posted: Wed Aug 20, 2014 7:58 am Post subject: Re: Barco 908 |
| larry9040 wrote: | | Projector is displaying blue screen ... |
Reboot the computer.
_________________ HansA, alles andere ist euer Bier!
| Posted: Wed Aug 20, 2014 9:37 am Post subject: |
| km987654 wrote: | | CasetheCorvetteman wrote: | | Pull it down and put up an NEC. |
That's one solution  |
Its generally a pretty good one too
larry9040
| Posted: Thu Aug 21, 2014 3:31 pm Post subject: BARCO 908 |
The lines are diagonal when looking into crt
larry9040
| Posted: Thu Aug 21, 2014 3:36 pm Post subject: BARCO 908 |
More Info: We are using an RGB Signal with sync on Port 5.
| Posted: Thu Aug 21, 2014 3:40 pm Post subject: |
Sounds like your blue CRT socket may be bad. If you pull it off the blue tube, do the red and green tubes work normally?
larry9040
| Posted: Thu Aug 21, 2014 3:57 pm Post subject: |
Internal test pattern comes up good, also failed to mention earlier, I2C 3CH IC109 CODE RGB Driver that was displayed.
larry9040
| Posted: Thu Aug 21, 2014 4:07 pm Post subject: |
We are getting a good image when using using a vga signal on port 3
redfox001
| Posted: Thu Aug 21, 2014 5:01 pm Post subject: |
| larry9040 wrote: | | Internal test pattern comes up good, also failed to mention earlier, I2C 3CH IC109 CODE RGB Driver that was displayed. |
That IC does left and right blanking and blue breakpoint and is located on the driver.
