nec 6pg plus step-by-step guide issue at page 6 please..
mookee
Posted: Wed Aug 13, 2014 7:03 pm    Post subject: nec 6pg plus step-by-step guide issue at page 6 please..
http://www.curtpalme.com/NECPG_MechSetup6.shtm
does it http://i.share.pho.to/168b49ee_o.png mean that the the first green cross hair horizontal has to be in perfekt 90degrees and if not that u should use the yoke drill to fix it? or what??
sorry i dont realy get it, may its the language i dont get )
ths
mookee
Posted: Thu Aug 14, 2014 9:08 am    Post subject:
actually its a general question about what to to, (after you did the first installation step by centering the picture on the tubes without lenses on), in step two, fireing the pj with its lenses on the first time..
mookee
Posted: Thu Aug 14, 2014 2:45 pm    Post subject:
like, if you set up your pj, any i guess, after you centered the picture/matrix on the tube and put on back the lenses for first projektion, does the horizontal cross pattern have to be in perfekt degree or how is step 2 ment PLEASE !!
mookee
Posted: Thu Aug 14, 2014 6:15 pm    Post subject:
okay okay, so i figured the horizontal line should be perfectly in degree (or paralell to the screen)...okay, it is.) BUT,..
what about the vertikal line; what if it is not in perfect 90 degree to my vertical. shall i do the vertikal "black thread with tape" string in perfekt 90degree to my horizontal line now (how;) or just the way the green horizontal line goes, even if not perfectly in 90 degree to horizontal? its not clearly formulated am affraid HELP PLEASE, AM SITTING HERE AGAIN AND CANT GO ON . /
lg c
ps. am watching "plains" in green now while i wait, so please hurry up!)
Posted: Thu Aug 14, 2014 6:43 pm    Post subject:
If you rotate the deflection yoke the horizontal line will turn along with the vertical line, so I'm affraid your should rely on the trusty old NEC's convergence alignment and convergence ability, namely: SKEW and TILT...
Does your projector in level BTW?
Also: If it doesn't bothers you that the the two lines are not rectangular, then leave it alone, otherwise use what you have Smile
mookee
Posted: Thu Aug 14, 2014 7:12 pm    Post subject:
hi gjaky
good to hear someone..) well, i live in an old building where nothing seems to totally rectangular and its hanging on the ceeling..so i cant change much there.
you mean when i rotate the yoke the horizontal AND the vertikal rotates...so it makes no sence at all to do so..or do you mean the horizontal line rotates and the vertikal stays...which would make even less sence for my problem, as the horizontal is fine...))
well, i guess i wont bother and so try to make a rectangular vertikal "black thread with tape" string through the "cross".. great, thanks!!
btw. "plains" on a 3 meter diagonal aint so bad at all, even in green.
lg c
mookee
Posted: Thu Aug 14, 2014 8:32 pm    Post subject:
no only that crts are pretty star wars anyway, you realy need the f**king force to be with you when calibrating them..
Posted: Thu Aug 14, 2014 10:33 pm    Post subject:
Not once you get how to do it. For instance, my first set up/calibration on my Sony 1252 took me around 6 hours.
Now I can set one up in 20-25 minutes.
