cine 9 scan fail
mrrepel
Posted: Mon Aug 11, 2014 7:28 am    Post subject: cine 9 scan fail
Edit: see post 9 below for accurate problem description
Posted: Mon Aug 11, 2014 7:53 am    Post subject:
Do the other functions on the remote work?
There is a setting to make it come on with a signal i think, but im not sure.
redfox001
Posted: Mon Aug 11, 2014 10:29 am    Post subject:
There is a jumper on the SMPS that disables standby. Perhaps that jumper is placed?
Posted: Mon Aug 11, 2014 12:24 pm    Post subject:
I dont know how to fix it but I love your Avatar !!!
Posted: Mon Aug 11, 2014 12:48 pm    Post subject:
you either have a fault on the controller board or the SMPS. I can fix them if you want to send them in.
mrrepel
Posted: Mon Aug 11, 2014 1:19 pm    Post subject:
Just mailed with my friend, seems that i didn't got all the information. After turning it on there is no light in the tubes and the set wont power off with the remote. Soon i'll go over and see / hear whats wrong. As he describes the hv isnt coming on and 'a' led is red lit. I'll be posting more when i've been there. Without a good discription of the fault i'ts a needle in a haystack...
And the avatar, made it myself to piss some off Mr. Green
the big E
Posted: Mon Aug 11, 2014 7:18 pm    Post subject:
Love the aviator man nice
crt king of black
mrrepel
Posted: Tue Aug 12, 2014 8:40 am    Post subject:
Hi all,
Just had a visit to the cine. Scanfail led is lit on the SMPS. It's a unit from oct. 2001. EHT down led isn't lit on the EHT board and the fuse is OK. I have an 808S for spares but the EHT board doesn't match:
Cine: R7627165
808S: R7617427
The tubes "light up" at the cathode. All leds on the SMPS are green ( except the SF ). All other boards with LED's are green. I can hear a light chirping sound after about 10 seconds by the SMPS. H-scan is green lit on the H-scan board
After a few minutes the chriping intensifies like the HV is coming on, then the complete machine switches off. After this the LED's are dimly lit on the SMPS and other boards
Posted: Tue Aug 12, 2014 12:55 pm    Post subject:
Bad power supply or H or V boards. The only way to narrow it down is to swap in other boards to see which one is bad, or send them to me, and I'll test and repair them.
