| Posted: Wed Aug 20, 2014 12:02 am Post subject: |
no but I would rather invest $140. into an HDMI capable receiver before doing that unless you have a special circumstance.
I am using an older higher end Denon and sending fully decoded Fluu Dolby 192Khz by having a slightly higher end BD player decode the audio and send it as 6 channel analog.
| Posted: Wed Aug 20, 2014 1:52 am Post subject: |
I picked up a set of 5.1 computer speakers. Since then I realized this only does old DD and DTS core so not much use.
I just got an Oppo 93 and an Oppo DVD player both with 7.1 and 5.1 outputs so this decoder isn't necessary. I'd still like to find a small box like this that will decode the newer formats and output to 7.1 or 5.1
Now if I can just find a SONY GDM-FW900 I'd be all set I currently have a SONY G520P for this mini system.
| Posted: Wed Aug 20, 2014 5:29 am Post subject: |
| AnalogRocks wrote: | I'd still like to find a small box like this that will decode the newer formats and output to 7.1 or 5.1
Found one!
http://www.atlona.com/HD570.html
Atlona AT-HD570
Model Number: AT-HD570
The Atlona AT-HD570 is a professional quality HDMI Audio De-Embedder. Unit is capable of accepting an HDMI input signal and de-embedding the audio signal to either Optical or Multi-Channel analog audio outputs. This audio decoder supports uncompressed analog LPCM 7.1, 5.1, 2ch through the mulit-channel analog outputs with Dolby Digital, LPCM 2CH and DTS output through optical connection. Supports Dolby TrueHD and DTS-HD Master Audio pass through HDMI connection.
Key Features:
Audio de-embedding through multichannel analog audio and digital optical audio output ports
Signal amplification and equalization to extend HDMI input and output ports up to 15 meters (50 feet)
Pass through audio up to Dolby TrueHD or DTS-HD Master Audio on HDMI
Pass through audio up to Dolby Digital / DTS 5.1 through the optical audio output
Pass through audio up to LPCM 7.1 through the analog audio outputs
Audio sample rate pass through of up to 192kHz
Pass through video up to 1080p@60Hz on HDMI
3D pass through
CEC pass through
HDCP Compliant
Resolution
Video 480i, 480p, 576i, 576p, 720p@50/60Hz, 1080i@50/60Hz, 1080p@24/50/60Hz
VESA 640x480, 800x600, 1024x768, 1280x1024, 1360x768, 1600x1200, 1920x1200
Colorspace YCbCr 4:4:4, xvYCC
Color depth pass through support of 24-bit
Audio
Formats PCM 2Ch, LPCM 5.1, LPCM 7.1, Dolby Digital, DTS 5.1, Dolby Digital Plus, Dolby TrueHD, DTS-HD Master Audio
Bit depth pass through support of up to 24-bit
Sample Rate 32kHz, 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz
THD+N -95db
HDMI IN
Features 3D, 1080p, 1920x1200, Dolby TrueHD, DTS-HD Master Audio
HDMI OUT
Multichannel OUT
Features PCM 2Ch, LPCM 5.1, LPCM 7.1
Optical OUT
Features PCM 2.0, LPCM 5.1, Dolby Digital, DTS 5.1
I think this may do what I want. Analog out to my Klipsch 5.1 PC speakers via 3.5(1/8") jacks.
| Description: |
| Filesize: |
59.44 KB |
| Viewed: |
4280 Time(s) |
