Different aspect ratios are brighter
jeffslife
Posted: Wed Jul 30, 2014 4:09 pm    Post subject: Different aspect ratios are brighter
When I watch 1.185 AR movies the image is bright and sharp and the gamma seems perfect. When I watch a 2.35 AR movie the image is darker and less sharp. When I watch 2.35 AR in 817P @ 72 hz the image is darker still ( too dark) and there is no shadow detail at all. Is it the lumagen HDQ ? I don't even watch in 72 hz for this reason.
We are ALL job creators !
Posted: Wed Jul 30, 2014 5:45 pm    Post subject: Re: Different aspect ratios are brighter
You need to calibrate your projector for each resolution, or stick to 1 resolution.
Check if you are using the same calibration profile in the projector, it might be running different profiles for different resolutions.
If the HDQ is using CMS, see to it use the same on all your output profiles.
Posted: Wed Jul 30, 2014 5:49 pm    Post subject:
Facepalm needed here.
jeffslife
Posted: Wed Jul 30, 2014 5:53 pm    Post subject:
All 3 were calibrated separately. I touch up the zone on all 4 separately. How do I check the calibration profile in the pj ?
Posted: Wed Jul 30, 2014 7:15 pm    Post subject:
If Craig has calibrated each profile in the projector it should be right, has it always been like this, or is it something new.?
jeffslife
Posted: Wed Jul 30, 2014 10:02 pm    Post subject:
I noticed it a few months ago but recently it seems to be getting darker.
Posted: Thu Jul 31, 2014 1:54 am    Post subject:
Best to talk to Craig.
Posted: Thu Jul 31, 2014 4:49 am    Post subject:
I agree, Crig know your serup, and will for sure be the best help you can get. The rest of us will just be guessing.
jbmeyer13
Posted: Thu Jul 31, 2014 3:24 pm    Post subject:
The CIR alarm just went off
Posted: Thu Jul 31, 2014 3:42 pm    Post subject:
Is thread for real?
jbmeyer13
Posted: Thu Jul 31, 2014 3:43 pm    Post subject:
Is thread for real?
LMAO Laughing Laughing Laughing
jeffslife
Posted: Thu Jul 31, 2014 5:59 pm    Post subject:
Apparently I might just have to wait for craig to chime in, no one else seems to have any ideas. At least not that they are sharing.
Posted: Fri Aug 01, 2014 1:58 am    Post subject:
No, the reason id say no one wants to share any thoughts is quite likely because you spent alot of money to have your set calibrated by Craig, so rather than suggest something that may lead you into f***ing that up, i would suggest speaking to him first.
the big E
Posted: Fri Aug 01, 2014 5:30 am    Post subject:
I agree with case don't F it up
crt king of black
jbmeyer13
Posted: Sat Aug 02, 2014 11:56 pm    Post subject:
Actually its because the answer is rather obvious. Think about the ar of the tube face and the content and it should become apparent.
Posted: Sun Aug 03, 2014 5:12 am    Post subject:
Not really, the projector is still capable of the same light output per area of tube face, so why would it now change if he hasnt moved the machine and the same area of tube face is lighting up the same area of screen?
Posted: Sun Aug 03, 2014 8:33 am    Post subject:
+1
And that would be quite easy to test.
Just run a 2.40:1 movie both as 1080P 60hz and 817P 72hz, if Justin is right they should look the same. At least if its setup and calibrated to do so.
jeffslife
Posted: Sun Aug 03, 2014 2:07 pm    Post subject:
72 hz is much darker than 60 hz. I thought I made that clear, sorry.
Posted: Sun Aug 03, 2014 4:56 pm    Post subject:
Thats what i understood to, i think you need Nash to help you out here, looks like he is holding something back.
