larryp
Joined: 24 Jan 2012 Posts: 252 Location: eden prairie mn
| Posted: Wed Jul 16, 2014 8:36 pm Post subject: How & What equipment do I need? |
Have a Sony 1272 using rgb connections & a Sony Switcher.
I want to drop Direct TV and use a over the air antenna for local channels.
Do I need a special type of converter or box? Not sure how this works and would hook up in my system.
I'm keeping my Roku 2 for most viewing. Thanks
the big E
| Posted: Wed Jul 16, 2014 10:10 pm Post subject: |
You can get a tv tuner box for HDTV I have one
I plan on building a media pc for my home theater and selling the tuner box(already have the pc done just have to hook it up)
I will sell the tuner if you want it I paid 150 for it new and it works great it uses hdmi or component video for the HD outputs
Let me know
| Posted: Thu Jul 17, 2014 1:51 am Post subject: |
You can get TV tuners here with RGBHV outputs.
| Posted: Thu Jul 17, 2014 4:30 am Post subject: |
Is the Kimcoder still available?
the big E
| Posted: Thu Jul 17, 2014 11:27 pm Post subject: |
Ar those are convertor boxs like is used with a analog tv
The one I have is for HD ready displays
| Posted: Thu Jul 17, 2014 11:53 pm Post subject: |
| the big E wrote: | Ar those are convertor boxs like is used with a analog tv
The one I have is for HD ready displays |
They can be used with an Analog TV via Composite for SD, Component for HD, or if your old TV had DVI/HDMI you can use that too.
You can also plug it into a Digital TV via component or HDMI. BUT in the case of the original poster, he wanted to know how to add OTA TV to his set up. One of these with a component to RGBHV transcoder should do it.
SO yes, you are right. Those are converter boxes that can be used with analog TV's but they also offer HD out via their HDMI and Component ports.
So for the OP larryP, You would need an Antenna, an antenna cable, ONE of the tuner boxes listed above, a transcoder ( such as the one listed above ) a set of cables to hook it up depending on your set up.
How do you currently have you RokU hooked up? HDMI Composite? etc... are you using any type of digital to analog converter ( Moome, HDFury etc...)?
larryp
| Posted: Fri Jul 18, 2014 4:51 am Post subject: |
Connected my Roku box to the moomie card in my switcher via hdmi cable Works ok, but HD movies etc don't come out as sharp as my Direct tv HD.
| Posted: Fri Jul 18, 2014 7:06 am Post subject: |
| larryp wrote: | | Connected my Roku box to the moomie card in my switcher via hdmi cable Works ok, but HD movies etc don't come out as sharp as my Direct tv HD. |
Which service a referring to watching HD movies on the Roku, Larry? What do you have for bandwidth on your internet service? Is the Roku connected to the internet via wired ethernet or Wi-Fi?
| Posted: Fri Jul 18, 2014 8:06 am Post subject: |
Does your Moome card have 2 HDMI inputs? If so forget the transcoder and go for an HDMI cable and let the Moome do the switching.
| ecrabb wrote: | | larryp wrote: | | Connected my Roku box to the moomie card in my switcher via hdmi cable Works ok, but HD movies etc don't come out as sharp as my Direct tv HD. |
SC |
I have seen this before also. My friend has a BoxeeBox and found when wired it was many times better.
hal
| Posted: Fri Jul 18, 2014 11:20 pm Post subject: |
Larry, just like Analog has mentioned.. Can you purchase a Moome card for your Sony and use the HDMI output of DirecTV.
That's what I do with my G90..
| Posted: Sat Jul 19, 2014 7:35 am Post subject: |
| hal wrote: | Larry, just like Analog has mentioned.. Can you purchase a Moome card for your Sony and use the HDMI output of DirecTV.
That's what I do with my G90.. |
Hal, you missed the part where he said he has a Moome card in his switcher. If it's the dual input HDMI then he can grab a tuner and an HDMI cable and allow the Moome to do the switching.
larryp
| Posted: Sat Jul 19, 2014 8:02 pm Post subject: |
Right now I have Amazon.
20mb dsl service
Roku is connected by Wi Fi
SC |
larryp
| Posted: Sat Jul 19, 2014 8:04 pm Post subject: |
Not sure what you mean? forget the transcoder? My card has 2 HDMI outputs, Latest card.
| AnalogRocks wrote: | | larryp wrote: | | Connected my Roku box to the moomie card in my switcher via hdmi cable Works ok, but HD movies etc don't come out as sharp as my Direct tv HD. |
SC |
I have seen this before also. My friend has a BoxeeBox and found when wired it was many times better. |
| Posted: Sat Jul 19, 2014 9:13 pm Post subject: |
| larryp wrote: | Not sure what you mean? forget the transcoder? My card has 2 HDMI outputs, Latest card.
SC |
Hi Larry, I initially recommended a Kim-coder RTC2200 component to RGBHV transcoder. BUT since you have the dual HDMI input on the Moome card you won't need it.
larryp
| Posted: Sun Jul 27, 2014 12:22 am Post subject: |
If I buy a HDMI "ad on box" for more imputs, will the moome card automatically switch to the source I'm using? Right now I have to select input 1 or 2 if I have 2 cables plugged in the inputs
SC |
