Neck Board Mod for LCP09 in 1209s?
gnnash
Posted: Wed Jul 02, 2014 1:10 pm    Post subject: Neck Board Mod for LCP09 in 1209s?
Finally got to refill my new green tube with glycol last night, no leaks as of this morning, after work I intend to put the tube back in and setup the projector.
However, I understand that I will need to do a mod to my neck board. Old tube was an LPB03, new tube is an LCP09.
Is it just as simple as putting a jumper between pins 2 and 6? Also, pins 1 and 2 are under a plastic cover, not extending out the back of the PCB. Will I have any noise issues with a long jumper from the back to the front of the neck card?
I found the following pinouts which suggest to me that a jumper between 2 and 6 would give me the missing G2 I need at pin 2:
Posted: Wed Jul 02, 2014 1:37 pm    Post subject:
Yes, jumper pin 2 to 6, that should do it.
barclay66
You are correct. I don't think that there will be any noise issue with the jumper wire. On the Marquee the G2 connection is always done with a single wire and a connector that goes straight to the tube's G2 input pin...
Regards,
barclay66
 Filesize:  30.18 KB
 Viewed:  2442 Time(s)
gnnash
Posted: Wed Jul 02, 2014 3:05 pm    Post subject:
Thanks for the confirmation!
Unfortunately, my neck boards do not have pins 1 and 2 exposed on the rear of the PCB, they are hidden under a cover on the socket itself, on the front side of the PCB. Kinda hard to explain without a picture...
Decibel
Posted: Fri Jul 04, 2014 9:31 am    Post subject:
You can remove (or make a little hole) in the cover of the socket, see the pictures below.
There's an extra pin 2 where you can solder a wire.
Pinout of R762839 neckboard
 Filesize:  53.69 KB
 Viewed:  2374 Time(s)
Open the cover of the socket
 Filesize:  70.27 KB
Pin 6
 Filesize:  54.98 KB
Remove cover of the socket
 Filesize:  74.65 KB
Domenico (Barco fan!)
gnnash
Posted: Mon Jul 07, 2014 12:53 pm    Post subject:
Right, that's exactly where I tapped into pin 2, it's the only location to do so.
There are already holes at the back (by the hinged part) of the cover to run a jumper wire out when you close it back up.
