conan7123
| Posted: Sun Jun 29, 2014 8:51 pm Post subject: Zenith Pro 861: short on HV/convergence power supply(solved) |
Hello, I have a big problem with my Zenith Pro 861 projector.
It was 8 or 9 years in the basement and my brother wanted to throw it away, so I grabbed it and was testing around with it.
The first 30 minutes the projector was working fine (okay, I only saw the menu because I didnīt had an bnc to rca adapter), but after I unplugged it from the wall and later wanted to use it, it wonīt turn on.
After I removed the backcover the fuse (250V, 2A) was blown out, a new one didnīt last long (blown out directly).
After some testing I figured out that the left power board ( your Zenith 841 page says HV and convergence power supply)
kills the fuse.
After I removed it , it turns on again (I hear the tubes and the speakers), so the left power supply must be shorted out..
Now the question is: Is there any way to repair the board or to get a replacement?
Or is the chance to high that the board has destroyed the other boards?
Any suggestion would be great
some pictures:
http://ts3.kev-ps-server.de/zenith/kpplpro861/IMG_6881.JPG
http://ts3.kev-ps-server.de/zenith/kpplpro861/IMG_6882.JPG
http://ts3.kev-ps-server.de/zenith/kpplpro861/IMG_6884.JPG
http://ts3.kev-ps-server.de/zenith/kpplpro861/IMG_6885.JPG
http://ts3.kev-ps-server.de/zenith/kpplpro861/IMG_6888.JPG
http://ts3.kev-ps-server.de/zenith/kpplpro861/IMG_6891.JPG
http://ts3.kev-ps-server.de/zenith/kpplpro861/IMG_6893.JPG
| Posted: Sun Jun 29, 2014 10:01 pm Post subject: |
Where were you 3 years ago? I threw out about 10 brand new 220 volt versions of this supply!
But.. I can help you fix yours, as it's usualyl a very simple fix.
The mica insulator behind the transistor on the heat sink fails, and shorts the collector (metal tab) of the heatsink to the metal heatsink, causing a direct short.
Replace the mica insulator, and it should work again.
conan7123
| Posted: Mon Jun 30, 2014 12:16 am Post subject: |
Hey Curt Palme,
youīre making me really happy right now
I think I will search for a new transistor tomorrow, I hope that will fix the board, but I have some consider..
The projector was bought by ebay almost 10 years ago and wasnīt used (my brother didnīt know that he must use the bnc input and not the y/c vcr rca).
The first problem I saw was that the ground cable on the socket was cutted, also the fuse (normally 250V, 2A) was a 250V 4A fuse, I hope the board isnīt grilled.....
But I have one more question:
I have some "basics" about electrical engineering (two weeks ago I have finished my education of information technology assistant - computer stuff) but i have tested some resistor and one resistor might failed, because I canīt measure it, also the blue thing (condensator???) behind it, my multimeter wonīt show any value.
http://ts3.kev-ps-server.de/zenith/kpplpro861/IMG_6894.JPG
What do you think about it?
| Posted: Mon Jun 30, 2014 12:59 am Post subject: |
I think the transistor and the capacitor (that's what the blue thing is I think) are probably fine. See the dirt behind the transistor?
Take the clamp off that holds the transistor to the heat sink, and pull the transistor forward. I'm sure that dirt will show up as an arcing point behind the transistor. Clean that up, put on a new mica insulator, and I'm sure it will be fine.
Heck, to test it, take the clamp off, pull forward on the transistor so that it is not touching the mica or the heatsink, and power the set up.
If it works and doesn't blow the fuse, you're fine as soon as you get new mica.
Don't run it for more than long enough to see if the tubes light up.
Also, Zenith made me a lot of money over the years by people that plugged their video (or cablevision RF) signal into the RCA Y/C connector. I did a service call once just outside of town, knowing the guy had it connected incorrectly, and despite me telling him 10X on the phone what the problem was, he insisted that I come out. I said it was $250, as it was a 2 hour trip, and I was there for about 3 minutes. He paid.
conan7123
| Posted: Mon Jun 30, 2014 1:25 am Post subject: |
I clean the transistor (isopropyl alcohol) and test it like this?
http://ts3.kev-ps-server.de/zenith/kpplpro861/IMG_6902.JPG
*edit*
cool, after i pushed it away from the heatsink, the solder breaked... where is my soldering iron..
Now I can unsolder it and clean it really good..
| Posted: Mon Jun 30, 2014 1:39 am Post subject: |
Exactly! you can measure across the 3 leads in all combinations with an ohmmeter to see if you get 0 ohms across any 2 leads. (if so, the transistor is probably shorted), but I'll bet it's OK.
conan7123
| Posted: Mon Jun 30, 2014 2:01 am Post subject: |
Nope, another blown fuse
http://ts3.kev-ps-server.de/zenith/kpplpro861/fuse *video of the new fuse :/ after i plug it in it gets killed*
I test it with an ohmmeter and between pin 1 and pin 2 it has a resistance at 20kOhm and its rising, pin 3 dosenīt make anything.
| Posted: Mon Jun 30, 2014 2:14 am Post subject: |
Hello
I would not spend much time or money on this thing, it is bordering on obsolete. You can find Barco or Electrohome machines under $1500 that would run circles around it
conan7123
| Posted: Mon Jun 30, 2014 3:29 am Post subject: |
Hmm.... I think I mess with it around a bit more
I donīt know if I would buy an projector..... This "little" machine didnīt cost me anything.. I also would need a screen to project on it
As a student you donīt have any money.. In September my apprenticeship starts (yay, money )
But I have looked around and found an Barco Graphics 801 for about 250 (~341 USD) not far away from me, it says:
2000 hours
no burns
technically okay
User Manual, Remote, cables
aand I could get an Barco 800 (not working) for tube or board replacement for free
Link: (German) http://kleinanzeigen.ebay.de/anzeigen/s-anzeige/beamer-roehrenprojektor-barco-801/205846901-175-2064?ref=search
I donīt know....
| Posted: Mon Jun 30, 2014 6:37 am Post subject: |
| conan7123 wrote: | But I have looked around and found an Barco Graphics 801 for about 250 (~341 USD) not far away from me, it says
I donīt know.... |
That is actually very expensive! I bought my XG135LC for 123 on ebay.de in this february... while it wasn't issueless, but still well worth it's price.
| Posted: Mon Jun 30, 2014 12:59 pm Post subject: |
OK, let me check my projector here, I know the 220 volt board is a bit different. I would check all semiconductors and diodes on the boards for a short. I'm sure you have a dead short on that board somewhere.
conan7123
| Posted: Mon Jun 30, 2014 2:16 pm Post subject: |
Okay, I will check for that thanks
But I contacted the person with the Barco 801 and I will try to go down to 150 (~204 USD) with the broken Barco 800 (my Dad would give me the 150)
I donīt know how to thank you all
conan7123
| Posted: Mon Jun 30, 2014 3:45 pm Post subject: |
Hmmm
I dont know what this means but I removed one Diode and used a 4A fuse (because I only have 2 of the 2Amps here) and the green tube comes on, i will solder the diode in and test it
*edit*
OoOoOoOo
okay... I soldered it all together with the old parts and now I use a 4 A fuse the f*cking thing powers up..... but the Picture is flickering as hell
*edit2*
okay, another dvd stopped the flickering
now I set it on my desk and try to configure it
I hope there are no mask/burns, but the tupes from the looking at seems very dirty -.-
*edit3*
but first I will flip the screen
| Posted: Mon Jun 30, 2014 5:18 pm Post subject: |
It looks like you have fungus in those tubes.
conan7123
| Posted: Mon Jun 30, 2014 10:10 pm Post subject: |
You need to take the tubes out, remove the glass, drain the glycol and fill with new stuff. Very common on those Zeniths, and that one is really bad.
Also make sure you properly clean and flush the LC chamber, especially the rubber bellows at the top, as lots of gunk gets stored in there. Pull everything apart and refill with clean glycol. I've got lots if you can't find any.
