Satanier
| Posted: Wed Jun 25, 2014 2:24 am Post subject: NEC XG-75 Flickering Issue (With Video!) |
I recently set up my XG-75 again and the third time using it this issue has occurred. I'm sending the PJ the same resolution and refresh rate that it worked with the last two times I used it: 1280x720@60hz. I have tried sending other resolutions such as 800x600 and this flickering happens with all of them.
View My Video
| Posted: Wed Jun 25, 2014 2:29 am Post subject: |
Post the video to Youtube, i cant view that from here.
| Posted: Wed Jun 25, 2014 2:31 am Post subject: |
you've lost vertical sync. Usually it's a bad BNC input cable, but I've seen the system board cause this as well.
Are the internal menus and test patterns stable? Have you inputted a video signal on the composite input?
| Posted: Wed Jun 25, 2014 2:32 am Post subject: |
Just tried on my work phone, no go there either.
