Netflicks and a Barco 808s
shelleybear
Posted: Fri Jun 06, 2014 12:39 am    Post subject: Netflicks and a Barco 808s
I've been running my Netflix account on my computer on an SVGA setting
The picture is fine, BUT I'm losing a lot of image off the sides (like you'd get with pan and scan.
The image is fine on my computer monitor but cut off on the projector.
Note: It seems to be blowing up the size of the image to the point of cutoff.
There is lots of room on the screen.
This happens mostly on Netflicks.
Playing a computer file I can compensate using the controls on Media Player Classic.l
Posted: Fri Jun 06, 2014 1:27 am    Post subject:
Uhhh
Try the short retrace setting on the 808 if available
Posted: Fri Jun 06, 2014 1:53 am    Post subject: Re: Netflicks and a Barco 808s
Are you running from a laptop? Often the second screen or projector will be seen as 4:3 instead of 16:9 in this case cutting off the sides.
shelleybear
Posted: Fri Jun 06, 2014 2:05 am    Post subject:
Running off a desktop with a 13 inch flat screen monitor.
I'm going to be switching to a wi-fi enabled Blu-Ray player as soon as I get my HDMI converter.
Posted: Fri Jun 06, 2014 2:23 am    Post subject:
You'll need to identify the second display and set the resolution for it. What version of windows are you running?
shelleybear
Posted: Fri Jun 06, 2014 2:44 am    Post subject:
XP.
I suppose I could disconnect the monitor and run it directly to the projector, but the second monitor solution sounds best
Could you give me the set-up instructions?
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_qfe.130704-0421)
Language: English (Regional Setting: English)
System Manufacturer: Hewlett-Packard
System Model: HP Compaq dc7100 SFF(PN924US)
BIOS: Default System BIOS
Processor: Intel(R) Pentium(R) 4 CPU 3.00GHz (2 CPUs)
Memory: 2552MB RAM
Page File: 589MB used, 2564MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.5512 32bit Unicode
Display Devices
Card name: Intel(R) 82915G/GV/910GL Express Chipset Family
Manufacturer: Intel Corporation
Chip type: Intel(R) 82915G/GV/910GL Express Chipset
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_2582&SUBSYS_3006103C&REV_04
Display Memory: 128.0 MB
Current Mode: 1024 x 768 (32 bit) (70Hz)
Monitor: Default Monitor
Monitor Max Res:
Driver Name: igxprd32.dll
Driver Version: 6.14.0010.4764 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 12/31/1999 19:00:00, 57344 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: igxpmp32.sys
Mini VDD Date: 12/31/1999 19:00:00, 5672032 bytes
Device Identifier: {D7B78E66-66C2-11CF-1061-0C10A5C2CB35}
Vendor ID: 0x8086
Device ID: 0x2582
SubSys ID: 0x3006103C
Revision ID: 0x0004
Revision ID: 0x0004
Video Accel:
Deinterlace Caps: n/a
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Not Available
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
shelleybear
Posted: Fri Jun 06, 2014 6:00 am    Post subject:
Could you please repost those instructions.
Posted: Mon Jun 09, 2014 5:50 am    Post subject:
Shelly have you tried switching the cables 1 to 2 and 2 to 1? Just to see what you get.
I don't have anything with that particular chipset. Generally speaking go into the graphics settings and try cloning your desktop you should get the same display on the monitor and the projector.
You should be able to do 16:9 in a 4:3 window. I did it all the time on my old HTPC at 1024x768.
Does anyone have a PC with this video chipset?
shelleybear
Posted: Thu Jun 12, 2014 8:08 am    Post subject:
Sorry this took so long.
I assume that what you mean was go to the projector's settings and duplicate the monitor's settings in one of the templates.
That seems straight forward enough.
Posted: Thu Jun 12, 2014 3:52 pm    Post subject:
No not the projector, the PC. Leave the projector alone for a moment.
Let's get both your PC's outputs producing the same picture first.
barcodude
Posted: Sat Jun 14, 2014 12:28 pm    Post subject: xbmc with barco 701multimedia
i got a old computer and turned it into a htpc with xbmc i strongly recomend a scaler to go with it like pixelmagic or a dvdo and let the size be calculated by the scaler and not the pc/laptop and use vga for output i get a great picture 720p because most streaming formats on xbmc are the best for a 701 cine7 or 7 projectors and jou will also have downloaded movie's that are ripped to 720p and vga has no handshake protocol like hdmi. Thumbs Up
