Problem with Autocal together with lumagen radiance
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    CurtPalme.com Forum Index -> ChromaPure Products
Drexler
Posted: Tue Jun 03, 2014 9:56 pm    Post subject: Problem with Autocal together with lumagen radiance
I have been having lots of problems my JVC X35 projector using Chromapure 125p autocalibration, a Lumagen Radiance mini 3D and an Eyeone Display 3 pro.
It seems to work fine to measure and get decent pre-calibration results. However, when running the autocal the end results gets all wacky with dE´s and gamma completely off the charts and a completely unwatchable picture. It starts out OK but every iterative step seem to put the calibration more and more out of wack.
I have been trying both to measure from the lens and from the screen, with gamma 2.2 and BT.1886, all producing weird, unusable results.
When I first got the equipment 18 months ago I had problems with the 2.2 gamma, but the BT.1886 worked fine, and it was the one I wanted, so I never bothered to look into it further. However, now nothing works anymore and I cant calibrate my projector!
I really hope someone here can help me. Thanks in advance!
Cheers, Ted
TomHuffman
Posted: Tue Jun 03, 2014 11:45 pm    Post subject: Re: Problem with Autocal together with lumagen radiance
Please send additional information to support@chromapure.com
I need two things to troubleshoot this.
1. A calibration report for a 125-pt session.
2. Copy/paste all of the text in the activity window into an e-mail and send that as well.
- Tom Huffman
ChromaPure calibration software & meter packages at CurtPalme.com discounted prices!
yoko
Posted: Sun Aug 17, 2014 6:49 pm    Post subject:
it's better to use BT.1886 or gamma 2.2 ?
if you choose BT.1886 in chromapure, which mode you select in your video projector (you don"t have BT1886 in JVC)
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    CurtPalme.com Forum Index -> ChromaPure Products All times are GMT
