Converter HDMI to RGBHV Analog Output for Barco 808s
shelleybear
Posted: Mon May 19, 2014 7:32 am    Post subject: Converter HDMI to RGBHV Analog Output for Barco 808s
Does anyone have a listing for models and brands for this device?
soleboy
Posted: Mon May 19, 2014 8:02 am    Post subject: moome ext-hd
Hello~
external solution : moome ext-hd, hdfury, and more
internal solution : greg eisemann mod
Posted: Mon May 19, 2014 9:26 am    Post subject:
On an 808 the MOOME V2 would be plenty, you probably wont be doing 3D with it.
Ile
Posted: Mon May 19, 2014 9:43 am    Post subject:
Better solution is around 10 dollar hdmi splitter from ebay to get "clean" digital signal to Lumagen hdp or similar cheap used scaler. Then use analog out from scaler.
With scaler you get also custom timings (almost mandatory IMO) and can use some better refresh than 60Hz.
1080i96Hz timings works great with 808.
shelleybear
Posted: Mon May 19, 2014 6:09 pm    Post subject:
Update:
Something I just remembered,
My 808s DOES have the piggy-back card on one of the boards
Will this do the job?
I also have the equivalent of a Lumigen processor as well as a receiver that has HDMI video in.
Posted: Mon May 19, 2014 6:30 pm    Post subject:
Despite what others say here (although all info is good info), I'd get the external box from Moome. Reliable, never had an issue with one, etc.
Second best would be a Fury, although the signal processing isn't as good.
You can try one of the cheapie HDMI converters on eBay, but you never know if they are going to work.
shelleybear
Posted: Mon May 19, 2014 7:34 pm    Post subject:
I tried to find a Moome on ebay, and got nowhere.
Ditto for Amazon.
Anyone have one to sell?
Posted: Tue May 20, 2014 2:06 am    Post subject:
Thats exactly what i said!!! Laughing
Posted: Tue May 20, 2014 2:16 am    Post subject:
Ditto for Amazon.
http://www.moomecard.com/moome/products/item/19-ext-fullhd-v3-3d-universal-hdmi
shelleybear
Posted: Tue May 27, 2014 6:17 pm    Post subject:
Something like this?
I'm using an iScan Pro as my doubler.
 Filesize:  11.65 KB
 Viewed:  3005 Time(s)
