Samsung hcn4727xaa error codes
the big E
Posted: Sat May 03, 2014 3:56 am    Post subject: Samsung hcn4727xaa error codes
Does anyone happen to know what it means when the power light flashes 5 times with no picture or sound from the set
You can hear the flyback kick on for about 3 seconds but nothing other then the power light flash 5 times
I think its the convergence amp board but I am afraid to replace the part till I know for sure
Anyone got any idea?
I do know if I get it working I will retube it as the blue and green are toast(already replaced the red tube)
Already replaced
Red tube
Neck boards
It gave a pic twice(once with the error code for the red neck board the other with the normal user interface)during the second time it started to flash the power light then the set shut down and hasn't shown a pic since
I am thinking if I can't get it working as is I will likely put a marquee 8500 in the chassis
crt king of black
the big E
Posted: Sat May 10, 2014 4:27 am    Post subject:
Bump anyone
If I can figure out what it is I will pull the guts out and put a marquee in the chassis(just have to make sure the convergence will work out in my favor)
crt king of black
