hiddink
| Posted: Thu May 01, 2014 10:13 am Post subject: DIY sync inverter for barco G 808 |
Hello,
Is there a good instruction around for building a sync inverter for the BARCO G 808?
Seen this video but no idea what materials are needed...
http://www.youtube.com/watch?v=6WdxnOQC4hM
Any help/pointers/manuals?
-brt
tschaeikaei
Joined: 08 Apr 2013 Posts: 490 Location: Germany/Saarland
| Posted: Thu May 01, 2014 10:41 am Post subject: |
I had that problem with my Graphics 400.
The cure was the tiny circuit pictured.
Maybe you should try different resistor values or simply use trimpots to adjust the voltage your 808 needs.
The Transistor could be every NPN small signal type that is rated high enough for your scan rate.
e.g. 1080 lines times 60Hz is 64kHz. Nearly every transistor is usable.
Maybe you want to have something more comfortable, then try one of these:http://www.epanorama.net/circuits/vga2rgbs.html
[/url]
edit:
Uhh, this is for CSync... maybe it is useful for you, too. But the simple sync inverter is this: http://www.twobits.com/RGB/sync.html
You need a 5V power supply (e.g. from a mobile phone). I would add a small electrolytic capacitor and a small ceramic capacitor between +5v and ground to avoid noise from the power supply.
_________________ Marquee 9500U edgeblend P43 | NEC 9PG
hiddink
| Posted: Wed May 07, 2014 6:18 am Post subject: |
Hello,
Sorry, I had not seen your reply since I did not receive an email although I had checked "I am watching this topic"...
Thanks for your answer...I'll look into it...
-brt
