xg blue tube prob
ccaddaddy
Posted: Tue Apr 01, 2014 2:13 pm    Post subject: xg blue tube prob
what causes half of my blue tube to be brighter than the other side? the right side is drastically brighter than the left side. im running 1440x788p from my hdleeza and feeding 1080i from hddvd player then finally to moome card.
"To forgive is divine but never pay full price for late pizza." Michaelangelo
Posted: Tue Apr 01, 2014 3:34 pm    Post subject:
Have you checked that the white uniformity and bright uniformity is set to midpoint under the REF. adjustments, also check if the blue electronic focus and astigmatism is even.
ccaddaddy
Posted: Tue Apr 01, 2014 4:58 pm    Post subject:
yes, i normaled everything as i am doing a full set up.
Posted: Tue Apr 01, 2014 11:56 pm    Post subject:
Dont ever zero anything in REF ADJUST.
Dont touch anything in there other than raster shift til youve got the mechanical sh** set properly.
Posted: Thu Apr 03, 2014 2:05 pm    Post subject:
What kind of screen are you using? Can you see the change in brightness on the tube face from one side to the other? If I remember correctly, some of the white uniformity/brightness uniformity settings should NOT be at midpoint, they should be at 0. I haven't had an XG set up in a while, someone that has a running XG might want to verify that.
If you haven't done a signal entry and gone into the color balance menu, then save the settings once the tubes normal out with the AKB line, one tube being brighter than another is pretty common.
Posted: Thu Apr 03, 2014 11:56 pm    Post subject:
Id be treating them like i do the pots in a PG...
Posted: Fri Apr 04, 2014 6:07 am    Post subject:
Case, they are perfectly safe to use, you can easily see by eye what is the optimal setting for them.
@Curt: you are right, I think the bright uniform should be at 0 (left most position)
Posted: Fri Apr 04, 2014 7:53 am    Post subject:
Yeah i mean dont adjust unless youre certain you know what youre doing
Posted: Fri Apr 04, 2014 1:09 pm    Post subject:
You can apply this rule to women as well, problem is that most men don't pay attention to this rule. Mr. Green
Posted: Fri Apr 04, 2014 9:39 pm    Post subject:
You can mate yeah, ive never met one of them that needed a password to access though Wink
ccaddaddy
Posted: Tue Apr 08, 2014 5:03 pm    Post subject:
I set some stuff to zero. it worked. i have one of those cheap $99 chinese screens. 100in. im gonna mess with this xg for a bit and see what happens. ive had these for about 5 years now and will use it until i burn something or cause a radiation meltdown.
