Decibel
Joined: 31 May 2007 Posts: 904 Location: Roma - Italia
| Posted: Fri Feb 28, 2014 1:40 pm Post subject: Swap cine7 tubes --> 808 |
Someone tried to swap cine7 P16's tubes into 808?
I just noticed that dimensions of tube's surface are absolutely identical.
The neck instead is more short.
The pinouts appear different but perhaps is possible to adapt the 808's rgb output boards.
Someone know if the electrical parameters of cine7 tubes are different than 180dvb's?
_________________ Domenico (Barco fan!)
| Posted: Fri Feb 28, 2014 2:09 pm Post subject: |
Yes, they are different. THe P16 Cine 7 tubes are ES focusing, the 808 tubes are EM. At minimum, you'd need to add the focus voltage and a way to control that focus voltage.
Decibel
| Posted: Fri Feb 28, 2014 2:22 pm Post subject: |
ooooops I wrote a nonsense. I have not thought about this obviousness.
| Posted: Fri Feb 28, 2014 2:25 pm Post subject: |
Hey don't think that I haven't wanted to do it in the past.. many times.
