Matt
Joined: 06 Jan 2009 Posts: 8 Location: Sydney, Australia
TV/Projector: Sony 1272, G70, G90
| Posted: Wed Jan 22, 2014 11:40 am Post subject: Why do you add the tissue tape when replacing tube in a G70? |
I was planning to replace the tubes in my G70 and have read through the procedure. I have a question which is; "why do you need to place two stripes of adhesive tape on the neck of the tube(s)?"
When I removed my original tubes, there was no tape on them. thanks.
| Posted: Wed Jan 22, 2014 12:04 pm Post subject: |
Nothing serious, it is because the coils are rigid and the tube neck is also rigid, so fixing he screws of the coils might not be enough to hold it right in place. Soft tape gives a bit more traction, and also helps softening the effect of accidental shocks between tube neck and the coils.
Matt
| Posted: Wed Jan 22, 2014 10:55 pm Post subject: |
thanks for the explanation, it is appreciated.
| Posted: Sun Jan 26, 2014 3:18 am Post subject: |
Use surgical tape.
