| Posted: Sun Jan 05, 2014 7:12 am Post subject: Macmini (1st gen) looses Os why? |
A friend of mine has a Macmini (1st gen) that generates a pretty weird problem. It seems to loose the OS after a while when not used, it only shows grey screen at startup in the middle with a toggling question mark and folder icon, nothing else. The system was reinstalled and it worked then even after a few days, and my friend put it away, when he tried to use it last time (after a few months rest) it only gave again the grey screen with the question mark.
The lithium battery holds the 3V, tried with safe mode booting - nothing, tried to reset the NVRAM -nothing... I've never heard of a HDD that forgetting its data, unfortunately there is no other mac around to assure the HDD's content.
So Macintosh gurus, how to solve this mistery?
| Posted: Sun Jan 05, 2014 6:55 pm Post subject: |
I tried, but it really looks from the setup side a blank install..
| Posted: Sun Jan 05, 2014 7:21 pm Post subject: |
| Nashou66 wrote: | do it from the install disc.
Nashou |
Yes I did that, it worked for a few days, and my friend put it away without using it, the next time (after few months resting) the macmini was blank again...
| Posted: Sun Jan 05, 2014 7:45 pm Post subject: |
Hmm, Did you try a MMU reset?
Turn of the mac, unplug it. Hold down the power button as you plug the
cord back in keeping the power button held down till you hear a beep or the mac "dong"
I can't remember which. Then let go of the button and restart it.
Then you might have to reinstall OSX and then do the same thing again.
