HDfury4 3D and Lumagen XS
pezzettino
Posted: Thu Dec 12, 2013 3:10 pm    Post subject: HDfury4 3D and Lumagen XS
Did anyone try this?
Marquee 9500 LC ULTRA with Moome VIM FULLHD V.3 HDfury4 3D and Lumagen XS
Posted: Thu Dec 12, 2013 4:03 pm    Post subject:
Why? You do not need the HD fury with the internal Moome.
pezzettino
Posted: Thu Dec 12, 2013 6:16 pm    Post subject:
Oh Nashou,
Now I get some images that are simply wonderful like what I see on MP screenshots. Unfortunately My camera isn't able to capture what my eyes see.
However I have problem when I play 3D material so from SKYHD 3D as BluRay 3D.
I have the LUMAGEN CRT 3D BOX connected with a good emitter and to the MOOME but I get bad results.
So I have read this thread
https://www.curtpalme.com/forum_archived/viewtopic.php@t=13415.html
and particularly this
I can see that HD FURY 4S will doubling, tripling and quadrupling 1080p24.. Now that was just what i was looking for.. emagine that any old VP or blu ray player can feed the Marquee, and just do the framerate multiplying on the Moome VIM.
then we dont need to worry about VP bandwidth anymore.. And i can test 1080P 96hz.
http://www.hdfury.com/shop/3dfury/hdfury-iv-advanced-kit/
Moome..PLEASE..
And then I need a valid hardware to play better 3D material.
I thought to put HDfury4 3D after Lumagen XS and then to connect this to the Marque RGBHV input and the same to the emitter.
Do I wrong?
I would like to know your opinion
Posted: Thu Dec 12, 2013 6:26 pm    Post subject:
If the XS does not have the 3D option then you won't pass the 3D frame packets. Is your XS 3D capable?
if so try 720p@120 for 3d I think that is what Craig round uses.
pezzettino
Posted: Thu Dec 12, 2013 7:45 pm    Post subject:
Yes, my XS is 3D capable and I already see 3D images.
And I use the same Craig settings. But are bad images and there is a bad sync
Posted: Thu Dec 12, 2013 7:46 pm    Post subject:
720P@96hz. Smile
Posted: Thu Dec 12, 2013 8:22 pm    Post subject:
Pezzetino, the Marquee's electronics need at least a 1us Sync timing or you get a wavy or squiggly artifact on all vertical lines.
You should put your timings into a VESA timing creator and see what the H sync is. if it is under 1us then you need to add more H sync pixels and then add the same amount you went up to H total pixel.
pezzettino
Posted: Fri Dec 13, 2013 9:44 am    Post subject:
I will search for
Posted: Fri Dec 13, 2013 1:36 pm    Post subject:
pezzettino wrote:
Oh Nashou,
Moome..PLEASE..
Do I wrong?
It was me who posted that, And its only a wish for displaying full frame 16:9 1080P 96hz, and the idea was HDMI in and out of the Fury 4. Doubt it will do the DA convertion better than the Momme card.
Its a bandwidth isue, The radiance will not do past 200Mhz out, the Fury spec say 225Mhz
Its all conected to the new MP mods, and dont have any relevance for standard Marquee
My post have nothing to do with 3D. I will never spend time and money on that on a CRT.
I think if it cant be done with the Radiance, the Fury will not do it to.
