| Posted: Wed Dec 04, 2013 4:15 am Post subject: New quad installed... |
I put a new quad in the CineMAX, that made it alot brighter and sharper...
The quivering is now gone and the focus works as it should!!
| Posted: Wed Dec 04, 2013 10:08 am Post subject: Re: New quad installed... |
| CasetheCorvetteman wrote: | I put a new quad in the CineMAX, that made it alot brighter and sharper...
The quivering is now gone and the focus works as it should!! |
Excellent. Good to hear you are getting some performance from that projector.
| Posted: Wed Dec 04, 2013 10:08 am Post subject: |
Since y'all love iphone pics...
This is via the MOOME V3 external...
| Posted: Wed Dec 04, 2013 10:20 am Post subject: |
And now one from RGB-HV...
The difference is pretty plain to see.
| Posted: Wed Dec 04, 2013 10:53 am Post subject: |
Yes it sure is. I found similar results.
| Posted: Wed Dec 04, 2013 11:30 am Post subject: |
Well im glad of two things there Keith!!
Im glad its not just me, and im glad someone with some technical credibility can vouch that there is a difference!!
| Posted: Wed Dec 04, 2013 12:01 pm Post subject: |
| CasetheCorvetteman wrote: | And now one from RGB-HV...
The difference is pretty plain to see. |
In the end it will turn out that the cine9 isn't a bad machine at all
| Posted: Wed Dec 04, 2013 12:13 pm Post subject: |
Its anything but a bad machine, it does have some short commings, but in time i will work around them and get it looking nice
ElTopo
| Posted: Wed Dec 04, 2013 1:49 pm Post subject: |
RGBHV looks sharper.
Where do the color difference come from ?
Same camera ?
stridsvognen Guest
| Posted: Wed Dec 04, 2013 6:53 pm Post subject: |
What resolution/ pixel clock are you using on those shots..?
Is it the source changing the color balance, or is it different projector calibrations.?
ElTopo
| Posted: Wed Dec 04, 2013 6:55 pm Post subject: |
Yo Nash could be.
@case: was it the same source (HTPC) ?
Francisco
Joined: 05 Apr 2007 Posts: 305 Location: The Netherlands
| Posted: Wed Dec 04, 2013 8:56 pm Post subject: |
Ah looks good exactly like mine
I use moome ext. V2 and also have little ghosting like yours. I'm supprised that your analog connection give such sharp image, how long are your cables?
_________________ Philips vacuum cleaner | Trystar double toaster | Car radio with orange plastic memory arrows | Class A Fridge
| Posted: Wed Dec 04, 2013 11:59 pm Post subject: |
Cables are about 6-8 meters, but theyre quadshield RG6 with compression fittings, so the length isnt an issue.
There is no ghosting. Not in either image, unless youre seeing something im not? You can see the second image is clearly better bandwidth. Im not sure which pic of yours you are refering to? I probably havent seen it. Post it up if you like.
Both are 1920x1080p at 60Hz, both from the same PC, both with the same standard timings.
The colour difference is cause neither had the colour balance touched.
The RGB-HV is sharper yes, and both pics are the same iphone 4S camera, simular position and angle, uploaded to photobucket.
stridsvognen Guest
| Posted: Thu Dec 05, 2013 12:01 am Post subject: |
| CasetheCorvetteman wrote: | Cables are about 6-8 meters, but theyre quadshield RG6 with compression fittings, so the length isnt an issue.
The RGB-HV is sharper yes, and both pics are the same iphone 4S camera, simular position and angle, uploaded to photobucket. |
Are you using 2 differnt input ports on the barco.?
| Posted: Thu Dec 05, 2013 2:11 am Post subject: |
No, both are going into PORT 4/5, but that makes zero difference on the CineMAX, i tried PORT 3 in the past with the same results.
Its quite clear where the short commings in this instance are, its the EXT MOOME V3 box thats killing it. You can see there plain as day with a couple blury iPhone pics.
stridsvognen Guest
| Posted: Thu Dec 05, 2013 6:31 am Post subject: |
What i wonder is it looks like with the moome there is a lot of roleoff to the 1:1 pattern, and peaking on the 2:2 pattern.
With the other source it looks like peaking on the 1:1 pattern and not so much on the 2:2 pattern.
How do green only look like.?
| Posted: Thu Dec 05, 2013 8:16 am Post subject: |
Green looked darker on MOOME in the vertical, normal on RGB.
The blue curve is a mile out, and on the 1:1 vertical with RGB, its abit fatter than green and red.
| Posted: Thu Dec 05, 2013 8:33 am Post subject: |
Its the same source both times by the way, just delivered differently to the projector, as i thought i stated quite clearly.
I think youre reading abit too much into it, considering the downsizing photobucket puts on the images.
This is exactly what i was saying about the external MOOME V3 in at least one other thread ( i wasnt the only one, at least 3 others backed my claim ) and you wanted proof of what i saw, there it is above. Accept it for what it is. I dont have a camera, only the iPhone 4S, i cant upload the full image cause this site wont let me upload a file that big, so photobucket is all youre getting.
stridsvognen Guest
| Posted: Thu Dec 05, 2013 8:51 am Post subject: |
| CasetheCorvetteman wrote: | Its the same source both times by the way, just delivered differently to the projector, as i thought i stated quite clearly.
This is exactly what i was saying about the external MOOME V3 in at least one other thread ( i wasnt the only one, at least 3 others backed my claim ) and you wanted proof of what i saw, there it is above. Accept it for what it is. I dont have a camera, only the iPhone 4S, i cant upload the full image cause this site wont let me upload a file that big, so photobucket is all youre getting.  |
Its fine.. Just wondering where that peaking is coming from. The moome for sure seems to be a huge limitation, specialy when considering the peaking addet.
Is there anywhere in the Barco to adjust that peaking like on some Marquee VIM boards?
A good way to check whats going on it to lower contrast and look into the lenses and see if the level of the vertical lines compared to the horisontal changes as you change the output/ contrast.
The pattern your using, is it not the same one where you told us that the 1:1 vertical lines should be darker, that the pattern was made like that?
