stridsvognen Guest
| Posted: Mon Nov 25, 2013 5:17 pm Post subject: PAL DVD 576P direct to 9" CRT ( no scaling) |
I had a fun experience the oher night after a bit of arguing about scaling, and source direct in another thread.
So what i did was to setup my Radiance and output 576P 100hz.
Spend some time playing with the stigmator to make the dots bigger to fill the scan line gap, also played with the focus.
The first impression was quite wow.
I have never made it before thinking that the scanlines would be to anoying, but with a decent distance to the screen i dont see them, about 3m from a 2m wide screen.
I later changed the framerate to 150hz, running a 81Mhz pixel clock. Kapow..
The detail level, and the dynamic range in the image is just amasing.
But i like to know how to make this better, whats the best way to adjust the dot size.? make them even in light output, not peaking in the center.
And would it be possible to do the same with NTSC 480P DVD signal.? Or will that be pushing the dot size to much.?
In the future im planing to run 2 Marquee 9500LC Ultra machines, so i can tweak one to SD source, and the other to HD.
If its better to adjust the mecanical magnet setup for SD. ??
barclay66
| Posted: Mon Nov 25, 2013 6:30 pm Post subject: |
I think that a combination of Astig and Focus settings will do the trick. I wouldn't touch the magnetic rings though.
Instead You could try the following procedure:
- Lower the focus on all three colors by 10-30% (not quite sure, raising could be needed instead)
- Set the electrical Stigmator settings such that the "smearing" happens vertically only
Now You can control the scan line size (line height) through the focus setting.
Regards,
barclay66
stridsvognen Guest
| Posted: Mon Nov 25, 2013 7:55 pm Post subject: |
Thanks barclay.
Its more or less what i did, and if ill be able to adjust the stigmator so the dots get vertical longer, ill never go back to scaling.
Its clear to see how scaling do mute some details.
There is 1 downside to it, and it looks like compression artifacts from the source, they also seems to get muted a bit when scaling, and thats the only positive thing i can say about the scaling.
Its a bit funny like i spend some years playing with different scalers to get a better SD image, and for the first time try to display it with no scaling, just gets blown away..
The only thing i do to the signal is deinterlacing and tripple the framerate to 150hz
Normaly i scale to 1080P 75hz, not the smoothest framerate for a 50hz source, but better than 60hz.
Im working with LD scaling to, and there it seems like the massive scaling from 480I 4:3 to a 1080P is a positive and effective noise reduction.
| Posted: Mon Nov 25, 2013 8:28 pm Post subject: |
I am wondering why would degrade the picture quality if you scale the DVD to double size (1440x960), that's a cheap old trick, no interpolation or estimation involved there, just doubling every pixel...
stridsvognen Guest
| Posted: Mon Nov 25, 2013 8:35 pm Post subject: |
| gjaky wrote: | | I am wondering why would degrade the picture quality if you scale the DVD to double size (1440x960), that's a cheap old trick, no interpolation or estimation involved there, just doubling every pixel... |
Ahh its not as simple as that, but sure more simple then 1080P.
As i see it no processing always win over any processing. There are ups and down. but nothing beats a 1:1 pixel mapping.
The chalenge on the Marquee is the screen size/ scanlines.
But i will try out 960P with different scalers when i have time, and see whats up and down.
| Posted: Mon Nov 25, 2013 9:25 pm Post subject: |
I have found the magnetic setup as specified by the projector manufacturer a compromise. You can make the image sharper for any resolution but of course it's only good for that resolution.
stridsvognen Guest
| Posted: Mon Nov 25, 2013 9:50 pm Post subject: |
| km987654 wrote: | | I have found the magnetic setup as specified by the projector manufacturer a compromise. You can make the image sharper for any resolution but of course it's only good for that resolution. |
I have the magnets setup for the high resolution high bandwidth, i know it wont work when adjusting those for low bandwidth and then display high bandwidth content.
But the other way i think its ok..
The marquee will store all the stig focus and others to each input selected.
| Posted: Tue Nov 26, 2013 6:31 am Post subject: |
Its not 960 high, its 1152
| Posted: Sat Nov 30, 2013 1:11 am Post subject: |
Stridsvognen, i ran my DVDs at 576p for years, and also agree it looked nicer than a 1080i upscale. ( watching blurays at 576p was clearly not as good as at 1080i )
Have you tried DVD using a PC instead of a stand alone player? I do put DVDs through the PC in my loungeroom setup now because the Barco wont fill the screen with the 1080p 50Hz signal my Panasonic bluray player pushes out.
I havent tried scaled vs untouched with the PC, i generally leave it set to 1920x1080 all the time.
stridsvognen Guest
| Posted: Sat Nov 30, 2013 2:21 am Post subject: |
| CasetheCorvetteman wrote: | Stridsvognen, i ran my DVDs at 576p for years, and also agree it looked nicer than a 1080i upscale. ( watching blurays at 576p was clearly not as good as at 1080i )
I havent tried scaled vs untouched with the PC, i generally leave it set to 1920x1080 all the time. |
Im using the Radiance XS+ to make the framerate convertion, and porch settings.
And the Marquee will fill out the screen.
Im now runing 575P 150hz.. And 1080P 72 hz.. So no scaling on any source.. just changes the framerare..
I can not look at 50 hz on my CRT.. i get sick..
Im using a Denon DVD A1 XVA who have HDMI 576P 50 hz 4:2:2 out, and its my prefered deinterlacer,
And for blu ray im using the old OPPO 83 1080P 24hz out
| Posted: Sat Nov 30, 2013 6:04 am Post subject: |
I don't use 50Hz for 1080i, but don't have an issue with it for 576p, I don't get any flicker at all.
