Universal Remote MRF-350RF directly connected to Barco 808s?
Malakay
Posted: Tue Nov 19, 2013 11:52 am    Post subject: Universal Remote MRF-350RF directly connected to Barco 808s?
Hi all,
i use a MX-810 remote. This remote sends the signals to the MRF-350RF reciever which converts the RF to IR.
Normaly i use the IR diodes and glue them to the IR input of the devices (Amp, Blu-ray, ..... ).
Now i see that the Barco 808s has a 3.5mm Socket on the front that can be used for remote Input.
Can i directly connect the MRF-350 RF to the 808?
Here is the manual of the MRF-350 RF:
http://www.universalremote.com/pdf/MRF-350Manual.pdf
I dont now, maybe this thread should be moved to CRT forums.
Thanks for your help!
Best regards
Chris
Beamer: JVC X35 (16:9 @ 2,8m Width(Cheap Trick))
Scaler: Lumagen Radiance XS+ (Color Management / Framerate Conversion)
BluRay: OPPO BDP-93EU / Sat: VU+ plus Duo2
PreAmp: Denon AVR-X4000 / Amps: Front L/R: Korsun v6i / Surr/BSurr: Denon AVC-A1 / Sub: Behringer EPX2800
Speaker: Teufel 6.1
barclay66
Posted: Tue Nov 19, 2013 2:02 pm    Post subject:
I don't think it will work and You may damage the MRF-350 RF by connecting it to the BG808s.
The MRF-350 RF uses a 5V signal (pulses) and uses two wires for the IR flashers. The Barco has +9V at his Remote connector (supply for the remote) and uses three wires. Even if You cut the +9V away it could be that the MRF-350 RF signal is either too weak and/or inversed polarity...
Regards,
barclay66
Malakay
Posted: Tue Nov 19, 2013 2:20 pm    Post subject:
Hi barclay,
thanks for your answer.
I didn't know that the remote input also provides the 9V. Ok, than i will glue the IR diode on the IR input, better not risk that something get's defective.
Danke!
Chris
Speaker: Teufel 6.1
HK-Steve
Posted: Tue Nov 19, 2013 9:33 pm    Post subject:
Yes, Barclay is correct.
