| Posted: Fri Oct 25, 2013 6:15 am Post subject: Recomend some screen material for CineMAX |
Ive been looking at some screen materials to make a new screen, im getting abit sick of painting the wall and never being able to get it ultra smooth ( im not happy enough with it... )
I saw this here:
http://www.projectorscreens.com.au/evo-ultra4k-screen-vinyl.html
...which looks like it might be a good option, 1.26 gain they say, ultra smooth for sharp focusing they say... Free shipping cause im in Australia, buying from USA could be cheaper to buy material, but the shipping will sure change that in most cases.
It seems as though some of the sharpness I seem to be losing on the Barco could be due to the surface of the wall not being perfectly smooth, so I would like it to be that way.
Here is a very close up shot of the surface:
| Posted: Fri Oct 25, 2013 1:34 pm Post subject: |
Have you tried sanding your current screen?
| Posted: Fri Oct 25, 2013 4:35 pm Post subject: |
There is no substitute for the Stewart ST130. Expensive, but the best.
It's what I use as do about 70% of all my clients including digital.
| Posted: Fri Oct 25, 2013 8:17 pm Post subject: |
Do they sell it on a roll for DIY Craig?
| Spanky Ham wrote: | | Have you tried sanding your current screen? |
Yeah mate, cant seem to get it right.
| Posted: Fri Oct 25, 2013 9:43 pm Post subject: Re: Recomend some screen material for CineMAX |
| CasetheCorvetteman wrote: | | It seems as though some of the sharpness I seem to be losing on the Barco could be due to the surface of the wall not being perfectly smooth, so I would like it to be that way. |
I can't offer any advice on material, but I think you're on the right track, Case... I noticed something similar soon after I switched from the G70 to the JVC. The light specular pebble finish that was fine with the (slightly) softer G70... It really seems to interfere with the definition of really fine detail with the JVC... It isn't that the detail isn't there; I think it's that the "grain" of the screen fights with the fine picture detail.
So, now I'm thinking about a newer screen, and going AT at the same time. Stewart isn't even remotely in the budget, so whatever I do, I'll probably end up with Seymour Screen Excellence Enlightor-4k. Just need to figure out size, how I want to mount it, if I want to change speakers, etc... Always with the decisions.
He has a 1.3-gain solid material for DIY, but I assume it would be cost-prohibitive to ship to Oz.
| Posted: Fri Oct 25, 2013 10:04 pm Post subject: |
| CasetheCorvetteman wrote: | Do they sell it on a roll for DIY Craig?
Yeah mate , cant seem to get it right. | what grit sand paper?
| Posted: Fri Oct 25, 2013 10:19 pm Post subject: |
I can't see how sanding is going to accomplish anything, Spanky... Sanding will take away material and level it, but there's no way in hell you'd ever get a nice, uniform consistent reflection and diffusion.
| Posted: Fri Oct 25, 2013 10:20 pm Post subject: |
What if you tried block sanding with a long board then adding another coat of paint?
| Posted: Fri Oct 25, 2013 10:35 pm Post subject: |
| AnalogRocks wrote: | | What if you tried block sanding with a long board then adding another coat of paint? |
Yeah, but then he's right back where he started.
Painting a good screen isn't trivial. You can get paint as flat as a mirror by block-sanding. The car guys do it all the time. The problem is then putting a nice smooth surface back down. Like we just said, the car guys block sand and polish. That won't work for a screen because then you end up with a shiny surface when you need matte - diffusion.
What you need is a very flat, but diffuse surface - something that's extremely difficult. There's a reason good commercial screens are expensive.
| Posted: Sat Oct 26, 2013 2:06 am Post subject: |
| ecrabb wrote: | I can't see how sanding is going to accomplish anything, Spanky... Sanding will take away material and level it, but there's no way in hell you'd ever get a nice, uniform consistent reflection and diffusion.
SC |
Yep, thats about it, if its shiny it looks horrid, if you sand it more coarse it looks scratched.
I installed a digital at work in a new sports bar project me and a couple other blokes are working on, i have a builder working with me and got him to make the screen from custom board. He did an outstanding job on it, painted with a sponge roller, looks great.
Difference there is its dead flat, mine is plasterboard with timber frame behind it.
zaphod
| Posted: Sat Oct 26, 2013 2:17 am Post subject: |
| ecrabb wrote: | | AnalogRocks wrote: | | What if you tried block sanding with a long board then adding another coat of paint? |
not really. if you sand after primer, and especially between top coats you get a much smoother result.
there is also the option of spraying on the paint.
| Posted: Sat Oct 26, 2013 2:51 am Post subject: |
There are ways to sand it without making it glossy. Of course with how cheap spray guns are these days, it would take very little money to spray.
Another alternative is one of the rigid substrates like Gatorboard or Sintra. I sent some samples to mechman and he posted the measurements on them about two or three years ago. I am not sure what the equivalent in Oz is, but these are sign boards.
| Posted: Sat Oct 26, 2013 2:55 am Post subject: |
Ive never heard of those items before.
| Nashou66 wrote: | Do you have any good white flat formica like wilson art? Might be a nice inexpensive alternative.
Nashou |
Not in that sort of size.
| Posted: Sat Oct 26, 2013 5:42 am Post subject: |
125" 5:4, i will have a look at that link.
| Posted: Sat Oct 26, 2013 5:45 am Post subject: |
Is 5x12 in feet?
Thanks for the links Nash
| Posted: Mon Oct 28, 2013 2:09 am Post subject: |
I might have changed angles on all this, so ill make a new thread... Thanks everyone for your inputs
