Considering doing XG75 stack
Larry K
Posted: Thu Oct 24, 2013 6:20 pm    Post subject: Considering doing XG75 stack
I'm not sure if this will work or not but I have two 75's that I am going to try on my PC just to see if they will look ok. What I would like to do is set up a system like this.
Pioneer BDP 05FD blu-Ray player to Darbie to HD Fury 4 with latest firmware to scale image output to 1920x800.48hz. to Gamma X to VGA splitter?? to both projectors.
The screen would be 108" by 45"
I realize I should probably go with two Gamma X units as each projector will likely require a different setting but that could be an addition as I have more money to throw at it.
So do you think this would work? Any insight would be greatly appreciated before I start spending money on this slightly insane project.
Posted: Thu Oct 24, 2013 6:56 pm    Post subject:
Hello
You will need green point convergence on both projectors, and if this is a side stack then some geometry settings will test the limits, such as H linearity. For side stacking, the projectors should almost touch.
Posted: Thu Oct 24, 2013 9:03 pm    Post subject:
Make sure you hushbox 'em! One XG is loud enough to require extensive hushboxing. Two would be crazy.
Larry K
Posted: Thu Oct 24, 2013 11:22 pm    Post subject:
The stack will be over/under and I will be building a false wall with insulation and the projectors will be shooting through glass so the theatre room is isolated from the noise, that is if my test tonight shows promise. I've got one on a coffee table and I'm setting the other just above it on a folding table. I'll let you know if there's any improvement in punch but also improved sharpness being that I should be able to dial contrast back??
Larry
Posted: Thu Oct 24, 2013 11:43 pm    Post subject:
Increase on on/off contrast will be significant. It's actually very addicting. Once you have two, it would be hard to go back to one.
However, any increase in sharpness due to reduced contrast setting will be more than offset by convergence on six tubes in two projectors.
Not trying to dissuade you at all. When I had two Sony 12xx, it was a fun experiment. Two XG's will be superior, and table-mounting two without much screen offset will be even better. Go for it... Just don't expect any increase in sharpness because that won't happen.
Question for you... How do you have the two projectors in a separate room, behind a wall, on a coffee table and a card table? I assume your viewing room most only be like 13-15 feet deep? Your viewing chairs will be flanking the projectors on either side of the projection port, I assume?
Would love to see a pic of this once you have it setup!
Posted: Thu Oct 24, 2013 11:45 pm    Post subject:
Oh, and if you stick with this setup, I'd plan on some kind of rack that you can bolt both projectors to so it's physically impossible to move one or the other. The setup on two projectors will not be lengthy and difficult, and it would SUCK to have somebody bump it and wreck a lot of hard work. A simple rack of 80/20 shouldn't be too expensive, and would keep everything nice and tight.
Posted: Fri Oct 25, 2013 12:02 am    Post subject:
Tim in Phoenix wrote:
Hello
None of this is an issue for an XG, or even a PG for that matter. They have about the best convergence system of any projector with the same adjustment ability on all 3 colours and plenty of range.
If youre going to want to go 1920x800, youre going to be better off blending instead, itll be sharper and youll use alot more tube face.
benareeno
Posted: Fri Oct 25, 2013 12:29 am    Post subject:
I'd love to try a stack...it would be damn fun!
So, if you have the projectors behind a wall, won't you be sitting extremely close to a huge screen?
Posted: Fri Oct 25, 2013 2:14 am    Post subject:
Stop 'considering', just DO it! Smile
I did it with two 9500s after I came back from Cliff's place 5 years ago. Apparently you need 24 man hours to do a full setup properly. I did mine in 4-5. Smile
I just did it for fun, but Zaphod saw it, and I thought it looked amazing for the lack of time spent on it.
Do it, post pix...
Posted: Fri Oct 25, 2013 2:29 am    Post subject:
Hello
And have a lot more headaches Wink
Posted: Fri Oct 25, 2013 2:47 am    Post subject:
It's been years since I've set up an XG, but... don't they have fairly limited point-convergence abilities? Cliff's G90's are awesome for a stack because they've got incredible geometry control. I remember it being hard enough to converge ONE XG, let alone trying to get TWO of 'em to agree. But maybe that was due to my lack of understanding at the time... the XG was my first projector. Embarassed
BTW Steve I think the coffee table / card table setup is a test bed to see if it works. If it does, THEN he moves it to the other room behind the glass. But yes, I would think you'd be mighty close to the screen that way...
Larry K
Posted: Fri Oct 25, 2013 4:18 am    Post subject:
The room is not set up yet and will only get built if I get these two units working well together and I'm happy with the results. Right now I'm sitting beside the beasts with only a 84inch wide screen. I like sitting close to the screen so I will be in front of the projectors at approximately one screen width based on the 9foot wide screen. The projectors will be setup with the lower projector inverted and hung at about 5 feet from the floor and the upper one sitting on it's feet upright on the shelf just above the lower bracket so they will be belly to belly as close together as possible. Gary, I was under the impression that XG's have one of the best point convergence control although I try not to use it unless absolutely necessary, that said, I'm not an expert by any means in setting these things up. I just muddle through and get a decent enough picture to enjoy mostly.
The biggest question I have is does my video chain plan make sense? Would all those components work and give me a decent result splitting the signal in the analog VGA state?
Posted: Fri Oct 25, 2013 4:44 am    Post subject:
No mate, although the Barco Cine 9 is abit like that, almost all point convergence and only 81 zones against NECs well over 200 zones.
POINT is the last port of call with an XG and rarely even needed in an ordinary setup. They have a very large range of adjustment in the regular settings, some people do seem to have abit of difficulty following the setup on the NECs but it is very easy and very quick when you know exactly what each adjustment does. There are so many it can take a bit to figure out which one will best get you the change you need, but once you know exactly what they all do, you will know the order to go in.
The adjustment range is enough on an XG that youd probably be able to stack with 3 of them side by side, if you could get the lenses focused well enough that way. The adjustments are also very fine with very small steps possible, so you would be able to very easily get perfect alignment even with 2 machines overlaid in a side by side stack.
If I was going to do it that way, I would set up the first machine, then converge the green of the 2nd machine to the red of the first, since all 3 colours have the same adjustment abilities.
As long as the PHASE is set perfectly on both, it shouldn't be hard at all. Thumbs Up
Posted: Fri Oct 25, 2013 4:58 am    Post subject:
Ive taken some pics, I will post them when they upload.
Posted: Fri Oct 25, 2013 5:16 am    Post subject:
The pics are of terrible quality and don't really show the side-shot keystone ability as good as it really is, but itll give an idea anyway. I had to stand off to the side to take the pics, which makes it even harder to tell.
Almost straight, zero keystone for reference:
V Keystone 100 under:
V Keystone 100 over:
H Keystone 100 under:
H Keystone 100 over:
Alignment menu:
Convergence menu:
Posted: Fri Oct 25, 2013 6:46 am    Post subject:
I've seen these remarks before about how awesome the convergence system is on the XG, but looking at the pics you posted, it looks like all the same sh*t my G70 had. Seems like when people talk about on projector being great, it's because that's the one they have experience with. Ever set up a G70 or G90? An Ehome Ultra? Or just the NECs (and now the Barco)? Don't all the last-gen digital chassis machines all have a pretty good geometry setup?
Posted: Fri Oct 25, 2013 7:22 am    Post subject:
Its not about what options it has, its about the FINE steps it has and the sheer number of adjustment points, that apparently the others DONT have. Its very obvious the more available points and the smaller the steps the better chance of getting it perfect.
Ive never set up a later model Sony or VDC, youre right and im not in any way claiming to know anything about them either, but ive seen so many people rave on about how great the Barco Cine 9 is compared to ALL those and ive gotta say, if that is what these people that have seen them all and set them all up think, its pretty poor compared to what NEC had back in 1992
Further more, this thread is NOT about Sony or VDC projectors, its about NEC projectors. Im quite sure they are all very capable, I never at any point stated any of those were not. Im sure you can get all of them perfect corner to corner on a standard installation with a perfectly flat screen.
Does a G90, G70, or VDC Marquee have 200 plus points of adjustment? Legit question, would like a legit answer, not interested in hearing opinions about whether or not that many points of adjustment are needed. Thumbs Up
