benareeno
| Posted: Sat Oct 12, 2013 4:14 am Post subject: lumagen question |
If I hook up something like a wd box via hdmi...will it still be hdcp?
In other words, can I view HD and output over 5bnc?
I understand that a Blu-ray player in through hdmi would only let you output over hdmi...but I'm wondering about other options.
Also, if I can do that...is there some sort of a hdcp stripper that simply strips it? THen I could ouptut from Bluray player to stripper, then to lumagen without hdcp...then vga into the projector.
Is this logical?
benareeno
| Posted: Sat Oct 12, 2013 5:34 am Post subject: |
Nash,
does that mean what I was asking above is true...it will work? If the hdmi goes in with no hdcp, I can hook up via vga?
This device seems to do the trick, but it's 290...200 bucks more than the lumagen
Is there a cheap bastard version??
I found someone selling a HDFury version 1...which will do the trick...but it would be after the lumagen. WHich is not ideal...but doable.
benareeno
| Posted: Sat Oct 12, 2013 5:35 am Post subject: |
do you do the gamma correction with your lumagen?
| Posted: Sat Oct 12, 2013 6:52 pm Post subject: |
You can pu the HD fury before the lumagen, the DVI connectors can be configured I believe for RGBHV or some of the component and composite are combined to make a rgbhv input. I would do it that way, if the HD Fury will send 1080p@24 then have the lumagen output what ever you want. For scope use 800p@72 etc. then use the lumagen for Greyscale and gamma at 11 points.
stridsvognen Guest
| Posted: Sat Oct 12, 2013 8:00 pm Post subject: |
| benareeno wrote: | Nash,
I found someone selling a HDFury version 1...which will do the trick...but it would be after the lumagen. WHich is not ideal...but doable. |
https://www.curtpalme.com/forum_archived/viewtopic.php@t=34454.html
Here is the best chepest solution..
Just strip HDCP, and then let the Lumagen do the DA converting in the end.
I tested it on 4 different VP.. worked perfect. For sure better than any HDfury solutions.
benareeno
| Posted: Sat Oct 12, 2013 11:21 pm Post subject: |
It looks like this doesn't strip hdcp...I was thinking I needed it to do that.
stridsvognen Guest
| Posted: Sat Oct 12, 2013 11:23 pm Post subject: |
| benareeno wrote: | | It looks like this doesn't strip hdcp...I was thinking I needed it to do that. |
What dont strip HDCP.?
benareeno
| Posted: Sun Oct 13, 2013 12:56 am Post subject: |
The link above..
| Posted: Sun Oct 13, 2013 2:22 am Post subject: |
You need a moom Mux-HD. You can put that between the source device and the lumagen you can then run RGBVH out of the Lumagen to the projector at 1080p etc.
stridsvognen Guest
| Posted: Sun Oct 13, 2013 7:31 am Post subject: |
| benareeno wrote: | | The link above.. |
Sorry if its not clear, but the 25$ HDMI splitter do strip HDCP perfect, You need to read all the thread i linked to.
As i told i tested it with 1080P 24/60hz HDMI in and 1080P60hz RGBHV out of 4 different VP.
It is the cheepest solution i know off if you already have a VP with RGBHV out.
The moome is another solution, just depends your needs for inputs, and how much money you have to spende.
