What tubes are original in the Barco 1209/2?
Posted: Thu Oct 10, 2013 9:38 pm    Post subject: What tubes are original in the Barco 1209/2?
Guys?
mx83toy
Posted: Thu Oct 10, 2013 10:34 pm    Post subject:
if im understanding your question correctly the answer will be the same for any machine... as square on to the screen as physically possible...
Hulio
Posted: Thu Oct 10, 2013 11:46 pm    Post subject:
@ mx83toy : It is possible that you just replyed on the wrong topic ?
@ Tim : a stock 1209/2 have Panasonic PT22-08 tubes. Not sure about the pinout but the neck is a bit shorter than LUG, LPB and LCP.
Posted: Fri Oct 11, 2013 12:02 am    Post subject:
I'm not in front of a set obviously, but I thought they are the LCP. the LUGs came later, in the 1209s sets, and teh 1209 may need a g2 pin mod in order to work with LUGs. Very easy to do on Barcos though, but it's been 5+ years since I worked on a 1209 so I could be wrong. Nothing wrong with doing the pin 2 to 6 jumper mod regardless on the 1209 just to be sure.
Decibel
Posted: Fri Oct 11, 2013 12:28 am    Post subject:
I found some pictures of 1209.
Unfortunately don't remember if was 1209 or 1209/2.
This machine have the green and red P19LCP07 and blue pt22-08
You can see that the neck of the blue is shorter than others.
But the neckboards are the same, so I assume that the pinout is the same.
Domenico (Barco fan!)
Posted: Fri Oct 11, 2013 12:34 am    Post subject:
Good call db, as I said, it's been a while... Smile
winny
Posted: Fri Oct 11, 2013 9:31 am    Post subject:
Decibel wrote:
Right, and to get to this point where you can take this photo, you need to remove the frontmost cover? The one with lots of screws and you ruin the mechanical settings in the process? I didn't find in the manual how to strip it down this far.
fragzero
Posted: Fri Oct 11, 2013 9:39 am    Post subject:
winny wrote:
Yes, take of all the screws you can find.
It won't ruin any settings, you will have to align the tubes again when it's on the ceiling anyway Smile
