yin
| Posted: Tue Oct 08, 2013 11:48 am Post subject: RS 232 Codes for Lumagen 2041 |
I am trying to figure out the Rs 232 Codes (Hex Dec) for the 2041 which I would like too buy but I want it to be controlled with RTI rs 232 and I would like too know if these codes would work or have I made mistakes. Maybe someone has experience with RS 232 and RTI
power On
23 25 3c 43 52 3e
Power Off
23 24 3c 43 52 3e
Cursor up
23 5e 3c 43 52 3e
Curser Right
23 3e 3c 43 52 3e
Cursor Left
23 3c 3c 43 52 3e
Cursor down
23 76 3c 43 52 3e
Enter
23 6b 3c 43 52 3e
Menu
23 4d 3c 43 52 3e
Exit
23 58 3c 43 52 3e
HDMI 1
23 69 31 3c 43 52 3e
HDMI 2
23 69 32 3c 43 52 3e
1080P
23 47 3c 43 52 3e
16:9
23 77 3c 43 52 3e
| Posted: Tue Oct 08, 2013 2:53 pm Post subject: |
Lumagen is a dream for RS232 control. It is very easy with short strings. All their codes are posted on their web site and are in the manual. If you know RS232 programming than you won't have any trouble. If you do have trouble just shoot Lumagen tech support an email with the questions and they will get back to you quickly.
Have no fear with Lumagen and RS232. Unlike most manufacturers it is very well implemented.
http://www.lumagen.com/docs/Tip0011_RS232CommandInterface_081413.pdf
http://www.lumagen.com/testindex.php?module=manuals
Have fun!
yin
| Posted: Tue Oct 08, 2013 7:51 pm Post subject: |
The question that I asked was are the codes that I posted correct?
I hope it is was not wrong to ask what the intire hex string would look like
yin
| Posted: Fri Dec 06, 2013 2:02 pm Post subject: Rs 232 Code for Standby does not work |
Hi Guys
I am using a RTI XP 8s the Lumagen 2041 is hocked up to it, my problem is I have the delimiters "On" and put in the "Standby code Hex 23 24 0D but it does not work.
Does anyone have a solution for me?
| Posted: Fri Dec 06, 2013 8:47 pm Post subject: |
Hi yin,
Are you an RTI dealer and/or are you very familiar with the RTI programming software? I'm not, but most systems have some way to denote hex bytes, to differentiate them from ASCII bytes so you can mix them in the same string. In some systems, backslash-x denotes the following two characters as a hex byte.
The Lumagen command format is #<command><CR>, so for standby, it would be #$<CR>.
So, that could be written:
#$\x0D
Your string could be written with all hex, so:
\x23\x24\x0D
So, I'd make sure you understand how to denote hex bytes in the RTI software.
The other thing to check is to make sure you have the serial port configured properly on the RTI controller, and that you're using the correct serial cable (NULL vs. crossover, or DTE vs. DCE).
Cheers,
yin
| Posted: Fri Dec 06, 2013 10:52 pm Post subject: |
Hi ecrabb,
all the other codes are working for the lumagen except this one "Standby" #$\r
"On" would be #%\r
So it can`t be a cable question because the other codes work
the serial port(RS-232)5 are all the same
so???
| Posted: Sat Dec 07, 2013 2:41 am Post subject: |
Ah, you neglected to mention it was all working OTHER than the standby command. That sounds like a Lumagen issue, then. Maybe standby can be disabled in the config menu or something. Hopefully Craig can chime in.
yin
| Posted: Sun Dec 08, 2013 7:02 pm Post subject: |
Found the mistake
