Larry K
| Posted: Tue Oct 08, 2013 2:03 am Post subject: Any way to play Blu-ray on PC without HDCP stripper? |
My External Moome box died and now I'm out of luck until I get it replaced. Even my PC blocked content from a commercial Blu Ray to be screened on my CRT projector. Is there any work around until I can get another HDCP blocking transcoder?
I'm thinking of going with the HD Fury 4 this time around.
Larry
| Posted: Tue Oct 08, 2013 2:30 am Post subject: |
If you need 3D get the 4 otherwise get a 3.
http://www.hdfury.com/buy-hdfury-now/
The Fury doesn't really strip anything it's more like an HDMI handshake..
Larry K
| Posted: Tue Oct 08, 2013 2:41 am Post subject: |
I like to see if I can set up the 4 as a scaler with the new firmware. According to the info you can now scale 1920x800 48hz using the HD Fury.
| Posted: Tue Oct 08, 2013 5:11 am Post subject: |
DONT buy one of those for a HTPC. Use RGB-HV straight out of the video card, you can get both 3D and normal Bluray that way and youll get a better image.
Use AnyDVD HD and whatever Bluray program you like. Any decent one will work. Its very easy.
The external MOOME death is no loss.
mx83toy
| Posted: Tue Oct 08, 2013 5:50 am Post subject: |
yep else do a search on a topic $25 stripper
| Posted: Tue Oct 08, 2013 9:14 am Post subject: |
Forget the stripper!! You can do it FREE.
Larry K
| Posted: Tue Oct 08, 2013 1:33 pm Post subject: |
I bought the $25 stripper, hope that statement doesn't get use against me some day... The problem is it's HDMI and I need RGBHV. I also bought the HDMI to VGA adaptor discussed in the same thread but it doesn't seem to work. I am going to try again with different cables just incase though. So I still need any DVD to make this work? I will give it a try tonight. Thanks for the suggestions.
Larry
| Posted: Tue Oct 08, 2013 2:15 pm Post subject: |
| CasetheCorvetteman wrote: | DONT buy one of those for a HTPC. Use RGB-HV straight out of the video card, you can get both 3D and normal Bluray that way and youll get a better image.
The external MOOME death is no loss.  |
What he said. AnyDVD HD will do the trick just fine.
