xg acat
ccaddaddy
Posted: Fri Sep 06, 2013 5:24 pm    Post subject: xg acat
where do i find one?
"To forgive is divine but never pay full price for late pizza." Michaelangelo
Posted: Fri Sep 06, 2013 5:47 pm    Post subject:
The meaning of the term ACAT changed during the years. the original ACAT was a camera based auto convergence system, probably the least useful, and most problematic amongst of all CRT auto convergence system, don't bother with that. Then with the last series of the XG NEC introduced the interpolated convergence setup tool, sometimes referred as MCAT, but appears as ACAT in the menu, this came with the XG 852 and 1352 projectors only, there is nothing you can do to add this feature to your older XG (...0, ...1)
Posted: Fri Sep 06, 2013 9:14 pm    Post subject:
You dont need it, the convergence on an XG is so damn easy to get perfect there is no point in complicating it.
If youve got a 1352 or 852 the ACAT is under the POINT menu, and does work reasonably well. Its still quicker and easier to just do it properly.
I connected and set up 6 sources on an 852 a few nights ago in about 2 hours, all from mid point.
At the end of the day, if you dont set PHASE correctly before you do anything else, youll struggle to get it right no matter what you do.
ccaddaddy
Posted: Mon Sep 09, 2013 5:29 pm    Post subject:
i dont understand phase.lol Confused
Posted: Mon Sep 09, 2013 5:39 pm    Post subject:
Before making any adjustments on a new (to you) machine it's worth to take a look at the phase adjustment, Phase sets the convergence reference point to the screen, if it is way off it's like you set something in the center and the edge is moving
Posted: Mon Sep 09, 2013 9:48 pm    Post subject:
What Gabór said. I can elaborate further later on if you like, but make no mistake, it all starts with PHASE on an NEC.
ccaddaddy
Posted: Fri Sep 13, 2013 6:50 pm    Post subject:
yes please elaborate.
Posted: Fri Sep 13, 2013 10:07 pm    Post subject:
When you start, you connect your source ( i use 240p for the first entry, i recomend you use to lowest you can, preferably progressive scan ), turn everything on, itll display a terrible out of alignment image, and you begin with PHASE, located at the bottom of the CONVERGENCE menu.
By this time, you have allready been to REF ADJUST and centered rasters, pointed tubes, done mechanical astig, done electronic astig, done focus, and everything is pointing dead center.
In the PHASE menu, the crosshatch grid will display, turn off red and blue, you will see a hump in the middle horizontal line of the green. You want that hump as close to dead center as you can. You also want the lines to be as close to straight as you can, or at least have the same curve radius from one side to the other. No bent up ends. You want the vertical center line to line up with the peak of the hump. When all this is done, exit and save.
Next up, crosshatch, set keystone and pin cushion close, turn off test pattern and using your source image, set amplitude and center the image using the image shift settings. Just get it all very close.
Now do blue and red linearity, especially horizontal ( vertical lines ) because after you do this, you will need to re-center your red and blue rasters ( i do this with the source image, which you have allready centered perfectly on the green ), then re-aim red and blue tubes. Use the cross hair for this, same as before. You do this because the center of the red and blue image is NOT the center of the tube face.
Next up, youve aimed the tubes, re-checked lens focus, called out to the wife for another beer, and mechanically aligned tilt/skew. Now you will do electronic tilt/skew, bow and center line distortion, starting with green, then merging red and blue to suit. Once done, you will have 4 same size boxes on your screen, separated by your perfect white cross hair.
Your green can now be aligned to the edges, this means keystone, pincushion, amplitude, key, pin and linear balance, linearity, line distortion, FINE RGB POINT, etc, til the image is right on the edge on the screen all the way around. You can start this off with the cross hatch, but finish it off with the green source image. Itll all be perfect, and its now time to start red and blue. Use of RGB POINT is your last resort, the others should get you pretty close to perfect, play around with each one and see what they all do.
You will have allready got the cross hair aligned for red and blue. It matters not which you do first on an NEC. Use all the settings listed above to get the red and blue ( one at a time, leave the other turned off ) perfectly aligned over the green. It all works nearly the same as the green adjustments, making it so f***en easy and quick to get it perfect it not even funny. Finish off with FINE POINT.
Save all this, then to default area as well.
I never use coarse POINT. Buy a Barco if you want to do this. Medium also rarely touch, its hardly needed in almost any case.
You could use an external text pattern to do the convergence, but in my experience its not required on an NEC, provided you set PHASE correctly at the start.
Gabór may wish to expand on this, but its all pretty simple.
Posted: Fri Sep 13, 2013 10:21 pm    Post subject:
Gabór may wish to expand on this.
No Very Happy Oh, only one thing, at the very end I find useful to set the point with all colors on, as you see better the red/green/blue glow of the test pattern if they are not matching exactly, so you can get the best convergence with minimizing the glow of the white testpattern lines.
jask
Posted: Fri Sep 13, 2013 10:29 pm    Post subject:
If you want further information read post #8: http://www.avsforum.com/t/98042/yikes-holy-focus-guy-kuo
and then re read it a few times.... it is not as hard as it sounds. Thumbs Up
Posted: Fri Sep 13, 2013 11:26 pm    Post subject:
Yep that is how i finish off.
We should also add that once its done right, you wont have to touch it for many many months of use. Everything tight, all set perfect ( i use binoculars for alot of the mechanical setup so i can be assured of perfection )
Thanks for that link Jask, ill check that out later too.
jask
Posted: Sat Sep 14, 2013 4:36 am    Post subject:
I used the binoculars a few times but found that a vidocam or dslr on a tripod made it a lot easier to visit w while adjusting.
Edit: autocorrupt
Posted: Sat Sep 14, 2013 4:50 am    Post subject:
I have read all that one before yes. I use the binoculars in the corner focus as well as centers.
the big E
Posted: Sat Sep 14, 2013 5:11 am    Post subject:
Wow long post but super informative (I need to copy this)
crt king of black
Posted: Sat Sep 14, 2013 6:24 am    Post subject:
Your 10PG will vary slightly, but not much.
the big E
Posted: Sat Sep 14, 2013 6:37 am    Post subject:
How slightly??
Also can the c elements between the nec and e home 9inch sets swap??
crt king of black
Posted: Sat Sep 14, 2013 7:18 am    Post subject:
In theory yes, they are the same, but on the 10PG they are glued there so hard that is near to impossible to remove them without damage. -But this is not directly connecting to this thread...
Posted: Sat Sep 14, 2013 7:21 am    Post subject:
No, its another thread for another day.
This is about XG convergence and how perfect it is.
the big E
Posted: Sat Sep 14, 2013 4:16 pm    Post subject:
Ok I thought I'd throw it out there while I was at it since I have both sets and am wanting a red c element for a 9inch marquee tube(will ask curt soon)
crt king of black
the big E
Posted: Sat Sep 14, 2013 4:18 pm    Post subject:
I know so back to the subject at hand as I also like to know this(may get a Xg if something happens to my pg)
crt king of black
