the big E
| Posted: Fri Aug 30, 2013 6:05 am Post subject: Ecp neck board crackles |
Ok I recently tried my spare bias/focus board(which I need to repair) in my Ecp only to get the blue tubes neck board start whistleing due to a hv leak
Now what I want to know is this a repairable thing(I do have the service manual) or is it best to find a replacment
I also have noticed the blue tube won't converge with the others on the left side(its not the schemfplug or the lens adjustment as the red tube does it some but not as bad as the blue tube)
One thing I want to know is it safe to run the set like this?(I fear of damaging the high voltage power supply and if it gets damaged I won't be able to use the set)
The noise seems to slow down some to a rapid ticking noise but goes away when ever the set locks onto a signal
I want to get it fixed as my cousin is wanting me to do a outdoor theater setup for an event he is doing soon and the Ecp is the easiest to move around(the movie would be at night)
