totalbhp
| Posted: Tue Aug 13, 2013 7:53 pm Post subject: Barco 808s no picture |
Hi my Barco has died it switches on but the tubes do not light up I have swaped all the boards from my spare 808 but still the same can any one help me please
| Posted: Tue Aug 13, 2013 9:23 pm Post subject: |
Check to see if the red LED is on on the EHT board. If so, you're in HV shutdown mode. the HV quadrupler or splitter is most likely bad in that case.
totalbhp
| Posted: Tue Aug 13, 2013 9:36 pm Post subject: |
Hi Curt thanks for the info but i have no idea which board is the EHT i look inside but could not see any red leds on only green so i swapped all the boards in the row one of the boards had 3 cables marked red green blue and the a plain red one but i is still the same .Dont know much about projectors
| Curt Palme wrote: | | Check to see if the red LED is on on the EHT board. If so, you're in HV shutdown mode. the HV quadrupler or splitter is most likely bad in that case. |
totalbhp
| Posted: Tue Aug 13, 2013 9:41 pm Post subject: |
Thanks curt i will have a look at that tomorrow as its quite late over here .
