Line level booster
MPHSystems
Posted: Thu Aug 01, 2013 1:23 am    Post subject: Line level booster
I need a small preamp, in the range of 6db. The problem is with a distributed av system (runs sound C5) and the oudio output from the directv STBs is substantially lower than the other sources. The MCA-C5 allows for 3db of adjustment but I am still not fully driving the amps. yes, I already went into the STBs and set the audio out to the highest setting
TIA. MPHSYSTEMS
If you know the whereabouts of Doug Baisy pm me
Posted: Thu Aug 01, 2013 1:46 am    Post subject:
Radio Design Labs (RDL) makes stuff like that. Not cheap new, but if you can find one on eBay, they're dirt cheap. I sold 25 assorted RDL modules for $41 last year. I sat on them for 10+ years, and never used one.
Edit Here, Zactly what you need:
http://www.ebay.com/itm/RADIO-DESIGN-LABS-RDL-STA-1-STICK-ON-UNIVERSAL-LINE-AMPLIFIER-w-POWER-SUPPLY-/161061943820?pt=US_Other_Pro_Audio&hash=item25800a3a0c
MPHSystems
Posted: Thu Aug 01, 2013 2:05 am    Post subject:
I see they make a balanced version too, do you know if they make a RCA version? In the past I have used an "audio buddy" it's just that with the 1/4" inputs and weird jack / knob layout they are awkward to tuck away in the back of a rack, and in this case I need 3 of them..
Posted: Thu Aug 01, 2013 2:50 am    Post subject:
Nope, only screw terminal. that's the way all RDL stuff is.
